Coolant Capacity http://www.gt4dc.co.uk/forum/viewtopic.php?f=2&t=536 |
Author: | GT4WRC [ Sun Jan 29, 2006 9:56 pm ] |
Post subject: | Coolant Capacity |
Anyone know what the coolant capacity is on an ST205? (engine - not WAI) Gary |
Author: | Kris [ Sun Jan 29, 2006 11:22 pm ] |
7.0 litres |
Author: | GT4WRC [ Sun Jan 29, 2006 11:42 pm ] |
Cheers. Time to fill up with some antifreeze now I think. Was running 100% H2O for the first 1000kms - helps bed the HG in apparently. Gary |
Author: | TrackToyFour [ Mon Jan 30, 2006 12:46 am ] |
Gary, we all run the Toyota red coolant in our engine cooling systems as well as our WTA intercooler systems. Not sure if you're doing the same? I made the mistake of using some 'ordinary' blue antifreeze and the corrosion effect was very noticeable after a period of time. Wish I'd used red coolant from the beginning now |
Author: | GT4WRC [ Mon Jan 30, 2006 1:43 am ] |
I'm using a green coloured coolant from a local parts auto supplier. What's the difference with the red stuff? As for the WAI, I'm just using water and water wetter. Gary |
Author: | TrackToyFour [ Mon Jan 30, 2006 2:43 pm ] |
I believe the Toyota Red Coolant is designed to inhibit corrosion of aluminium alloy. Also, the Red Coolant is specifically recommended for the ST205 intercooler. If I can find the official reference to this I'll let you know. In the meantime can anyone else quote the actual Toyota reference? |
Author: | Kris [ Mon Jan 30, 2006 6:29 pm ] |
Quote: can anyone else quote the actual Toyota reference?
Unfortunately not. But just to echo what Don says, I'd only use the red stuff... I've taken a few things apart and I've noticed some corrosion forming on the internals of some pipework when not running red stuff. I have found that pipework is in very good condition internally if it runs red stuff. Maybe I'm just being lucky but I suspect that running coolants that do not have the same properties as the Red Stuff are not inhibiting the corrosion sufficiently. Ker-plink! |
Author: | GT4WRC [ Mon Jan 30, 2006 8:03 pm ] |
Cheers chaps Looks like a little trip to the Toyota dealer is in order... Gary |
