It is currently Sun Apr 28, 2024 9:07 pm
 Post subject: 185 tein coilovers
PostPosted: Fri May 31, 2013 6:05 pm
Hi guys :), would anyone happen to know if rear topmounts are still obtainable for said suspension ? Also has anybody heard /seen of a reaction from the topmounts fitted to the rear of a car :? , reason being I have first refusal on a set only both rear tops are all but useless, in fact one has crumbled so badly a mounting stud has just broken away and the other side is looking pretty much the same :shock: . Could this be avoided in the future assuming I sourced replacements ?
2004 Subaru WRX
 Post subject: Re: 185 tein coilovers
PostPosted: Fri May 31, 2013 9:56 pm
I have a set of the old Tein HA. Exactly the same has happened to the rear top mounts. I don't think replacements are available on their own but I intend to either modify a set of other top mounts or get soem custom adaptors made up.
There were a few options of top mounts but I am not sure which are still available.
PostPosted: Fri May 31, 2013 10:03 pm
:( Bloody hell :(, tbh since posting I've fired off a couple of e-mails but it seems probably a waste of time then ? Bc here we come :lol:
2004 Subaru WRX
PostPosted: Sat Jun 01, 2013 6:53 pm
I thought they still offered them for their SS 185 suspension, I think they may work for the HAs.
Coldiron (Cold - Iron)
http://www.noritoy.com
PostPosted: Sun Nov 30, 2014 7:20 am
You might look at t3 top mounts. I got some and use them on my HAs since they have caster adjustment.
PostPosted: Wed Dec 03, 2014 10:24 pm
Hi Homer,
As i recall one can purchase camber adjustable rear top mounts as separate items from BC...
T3? never heard of them until now: https://technotoytuning.com/toyota/st18 ... ber-plates
^^^ cheers for the heads up
ST165 turbo 4WD
PostPosted: Wed Dec 03, 2014 10:57 pm
Here is a little vid I did installing them on the teins. https://www.youtube.com/watch?v=7vAebT2 ... 6KBWr0FklA
They make a lot of toyota bits, and trying to get into our chassis.
PostPosted: Thu Dec 04, 2014 6:09 am
Thanks Guys for the recent input on this topic , good info about the T3 parts available :) . I didn't purchase the tein setup in the end although i did establish the rear mounts were still available separately .
2004 Subaru WRX
Users browsing this forum: No registered users and 183 guests
