car cutting out http://www.gt4dc.co.uk/forum/viewtopic.php?f=2&t=6643 |
Author: | tjaytoymota [ Tue Jul 23, 2013 5:24 pm ] |
Post subject: | car cutting out |
any ideas start car runs fine revs fine goes fine randomly cuts out will not restart oh and doaes anyone know what voltage i should have at fuel pump any help appreciated cheers Ted |
Author: | Nibbles [ Tue Jul 23, 2013 6:14 pm ] |
Post subject: | Re: car cutting out |
Worth checking error codes as a first step. http://www.gt4dc.co.uk/info/howto/ecu/e ... _codes.htm Fuel pump should be 12V ish or at idle / light load a resistor is swited in series which will drop it to about 8-10V |
Author: | tjaytoymota [ Tue Jul 23, 2013 6:49 pm ] |
ideal thanks was getting 9v wasnt sure if that was right no error codes drives fine just really random wish it would just stop completely so i could find something ![]() |
Author: | DeeCee [ Tue Jul 23, 2013 10:14 pm ] |
Have you recently disconnected the battery? If so, you need to take it for a decent drive for the ECU to re-learn idle point. Also, check battery is holding voltage |
Author: | tjaytoymota [ Tue Jul 23, 2013 11:47 pm ] |
yeah have tried that and brand new battery,it almost seems like its either flooding as i leave it for 20 mins it starts trouble is it does it with cold engine or warm engine and sometimes not at all.earlier i cleaned battery terminals stopped and stared 10 times in a row went for long drive started stopped ok got home stopped started ok stopped again wouldnt start now got bald patches as pulling hair out llol |
Author: | Nibbles [ Tue Jul 23, 2013 11:48 pm ] |
If you have an immobiliser fitted, these are renowned for having a relay contact fail and intermittantly prevent running. Also, have a look at the following thread, the ECU is under the dash behind the centre console, pull back the carpet that sticks up on each footwell to access. This is now a VERY common problem on RC & CS models - worth a look and if you find one or both capacitors has leaked it can be repaired by a local electronics place or I can do it. IMO worth changing them anyway before they damage the board (they only cost pennies). viewtopic.php?f=2&t=5617 |
Author: | tjaytoymota [ Wed Jul 24, 2013 12:01 am ] |
thanks could well be that as i have a management light ghosting on off with no stored codes,will give it a try let you know |
Author: | Nibbles [ Wed Jul 24, 2013 12:07 am ] |
tjaytoymota wrote: thanks could well be that as i have a management light ghosting on off with no stored codes,will give it a try let you know One of the prime symptoms. If you don't have or know a decent electronics place locally I can do it remotely by post or I come down to Newquay fairly frequently if you're anywhere near there. Once you have symptoms, there's normally tracks to repair / bridge as well as just replacing the capacitors. |
Author: | tjaytoymota [ Wed Jul 24, 2013 10:13 am ] |
Yeah ideal not far from Newbury in the Mean time can I run a data ecu I have lying around?cheers. Ted |
Author: | tjaytoymota [ Wed Jul 24, 2013 1:23 pm ] |
Newquay ![]() |
Author: | Nibbles [ Wed Jul 24, 2013 10:07 pm ] |
a data ecu ? I may be in Newquay Friday or Sat evening, not sure which one yet but Saturday looking more likely. |
Author: | tjaytoymota [ Wed Jul 24, 2013 11:51 pm ] |
Lol poxy predictive txt I meant normal ecu with air intercooler gonna take ecu out tomorrow will pm you my no as will have done either way just let me know cost cheers |
Author: | Nibbles [ Thu Jul 25, 2013 8:44 am ] |
If its from a later 185 it may work but keep the boot light and stay off boost. |
Author: | tjaytoymota [ Thu Jul 25, 2013 12:52 pm ] |
ok nibbles looks like i need repair if you can do ![]() ![]() ![]() ![]() |
Author: | tjaytoymota [ Fri Jul 26, 2013 9:06 pm ] |
Chris your a star everything good and fixed rev counter gave it a tap lol thanx again Ted |
