It is currently Fri Apr 26, 2024 1:06 am
 Post subject: Honing
PostPosted: Fri Sep 27, 2013 7:17 pm
Hello
I am about to hone my 3sgte
How much can i hone it ?
There is small scratches in two cylinders that i need to take
Can I honing it until it goes or ?
When do I know That I have to get it drilled to oversize ?
Regards
Toyota Celica Gt4 1990
Toyota Celica Gt4 1990 Rallycross
Toyota Starlet 1980
 Post subject: Re: Honing
PostPosted: Fri Sep 27, 2013 7:46 pm
Honing is not done by the home mechanic... take it to a machine shop
Take it this is a "quick repair" to a damaged engine?
PostPosted: Sat Sep 28, 2013 9:39 am
Measure the bores with a bore gauge (further down cylinder where the wear is ). From my fairly limited experience anything .05 to .1 mm oversize is much more prone to ringland failure.
if you're looking for a quick cheap fix you may be better leaving the scores as you get very little blow-by down a narrow scratch.
if you're running big power you need to.do it properly.
PostPosted: Thu Oct 10, 2013 7:34 pm
As above take it to a machine shop its not something to take on lightly as it controls oil usage, etc as well as other things mentioned.
I have built hundreds of engines and I still prefer to pay my machinist to hone my engines for the cost its not worth the mess of the cooling fluid and the cost of the correct honing stone, etc
Martin
We now have a new website
Users browsing this forum: No registered users and 44 guests
