Front Transfer box top up. http://www.gt4dc.co.uk/forum/viewtopic.php?f=2&t=6772 |
Author: | yellowchinaman [ Wed Oct 02, 2013 3:47 pm ] |
Post subject: | Front Transfer box top up. |
I changed my prop shaft today and let out some oil. Do I top up via the gear box filler plug is? Mine is seized so is there another way? |
Author: | wolfiehere [ Wed Oct 02, 2013 6:43 pm ] |
Post subject: | Re: Front Transfer box top up. |
You can put itin through the top breather but not recomended as you wont know if you've over filled it. But yes you add through the fill up pipe. Sent from my GT-P5110 using Tapatalk 2 |
Author: | Nibbles [ Wed Oct 02, 2013 6:57 pm ] |
Gear oil for the whole lot goes in via the filler hole on the front. When it starts dribbling out it's full. |
Author: | yellowchinaman [ Wed Oct 02, 2013 8:44 pm ] |
Where is the breather? |
Author: | dale [ Thu Oct 03, 2013 11:21 am ] |
Nibbles wrote: Gear oil for the whole lot goes in via the filler hole on the front. When it starts dribbling out it's full. this |
Author: | yellowchinaman [ Fri Oct 04, 2013 9:57 am ] |
yellowchinaman wrote: Where is the breather? ^^^^ |
Author: | Nibbles [ Fri Oct 04, 2013 10:17 am ] |
On top. |
Author: | yellowchinaman [ Fri Oct 04, 2013 1:05 pm ] |
sorry but I really couldn't figure out which one it is on top. Can some one tell me where on this pic is the breather pls? |
Author: | wolfiehere [ Fri Oct 04, 2013 6:28 pm ] |
Behind the starter between the 24mm bolt. It has a circular cap that spins you will need to pry it off Sent from my GT-P5110 using Tapatalk 2 |
