water pipes, where do they connect? IMAGE CORRECTED http://www.gt4dc.co.uk/forum/viewtopic.php?f=2&t=6790 |
Author: | niblettr [ Mon Oct 14, 2013 11:40 am ] |
Post subject: | water pipes, where do they connect? IMAGE CORRECTED |
pretty sure A and B are the throttle body heater lines (so bridge together?) Any idea where C would go? (C is on the water elbow) Thanks |
Author: | niblettr [ Tue Oct 15, 2013 9:15 am ] |
Post subject: | Re: water pipes, where do they connect? |
corrected the photo upload.... |
Author: | asdrewq [ Fri Nov 01, 2013 9:51 pm ] |
Post subject: | Re: water pipes, where do they connect? IMAGE CORRECTED |
Isn't that one of the turbo coolant lines Are you operating the standard PCV system? If so probably best to keep throttle heater pipes connected, it will help prevent the idle control valve becoming blocked with congealed gunk. |
Author: | niblettr [ Sat Nov 02, 2013 2:40 am ] |
It's pointing the wrong way to be a turbo coolant line? |
