It is currently Sun May 05, 2024 2:02 am
PostPosted: Thu Jan 23, 2014 8:49 am
Hi guys possibly another daft question but I'm going to compression check my car and I was wondering if I can get to them without removing the charge cooler completely? If I do remove the charge cooler will I lose all my coolant? Thanks
PostPosted: Thu Jan 23, 2014 9:29 am
You should be able to leave. The pipes connected and lift through nearly 90 degrees to get access.
PostPosted: Thu Jan 23, 2014 11:17 am
Yep you will be able to leave in place, use a bit of wood to prop it up.
If you remove it you'll lose coolant yes and it will get messy unless you drain it properly from the radiator.
PostPosted: Thu Jan 23, 2014 1:26 pm
Thanks a lot guys
Users browsing this forum: No registered users and 27 guests
