ST205 front wheelbearing advise http://www.gt4dc.co.uk/forum/viewtopic.php?f=2&t=6907 |
Author: | jdm-gt4 [ Sun Jan 19, 2014 10:59 pm ] |
Post subject: | ST205 front wheelbearing advise |
hi think ive got symptoms of the front wheelbearing starting to fail whirling/whinning getting worse with increase in speed but looking on prices. i see that at TCB they are £80 and generic £39 would there be any difference? (quality wise) as its quite a difference in price also out of interest, how long (labour wise) would it take for a garage to change |
Author: | TrackToyFour [ Mon Jan 20, 2014 12:11 am ] |
Post subject: | Re: ST205 front wheelbearing advise |
It took a full day for an experienced GT-Four mechanic to do a front and a rear bearing on my ST205 but that was because the rear put up a bit of a fight. Personally I would fit either a genuine Toyota or a generic Blueprint bearing. Anything else I would suspect is made of finest Chinese chocolate |
Author: | Kris [ Mon Jan 20, 2014 5:26 pm ] |
Go for the Blueprint wheel bearing kit - you'll also need the seals as well as the bearing... |
Author: | jdm-gt4 [ Mon Jan 20, 2014 7:32 pm ] |
thanks for the replys any info on the part number for the blueprint kit, bearing and seals? as ive got a mate at a motorfactors so if i know exactly what i need, id get a discount thanks |
Author: | TrackToyFour [ Mon Jan 20, 2014 8:11 pm ] |
I've got a couple of spare Blueprint bearings for my ST205 so I'll dig out the part number. Not sure about the seals Kris mentions? I don't recall buying them, only the CV rubber gaiter. |
Author: | jdm-gt4 [ Mon Jan 20, 2014 8:34 pm ] |
TrackToyFour wrote: I've got a couple of spare Blueprint bearings for my ST205 so I'll dig out the part number. Not sure about the seals Kris mentions? I don't recall buying them, only the CV rubber gaiter. thanks appreciated with regards to the seal kit, im under the impression you can but the bearing on its own or with the seal kit, id also want the seal kit |
Author: | TrackToyFour [ Tue Jan 21, 2014 1:28 am ] |
Blueprint Part No. ADT38322 Contents: Bearing x 1 Seal x 2 Ancillary x 1 Split Pin x 1 Grease x 1 |
Author: | jdm-gt4 [ Tue Jan 21, 2014 8:01 pm ] |
TrackToyFour wrote: Blueprint Part No. ADT38322 Contents: Bearing x 1 Seal x 2 Ancillary x 1 Split Pin x 1 Grease x 1 thanks, others should also find this info helpful |
Author: | martinking6 [ Fri Jan 24, 2014 11:10 pm ] |
TrackToyFour wrote: It took a full day for an experienced GT-Four mechanic to do a front and a rear bearing on my ST205 but that was because the rear put up a bit of a fight. Personally I would fit either a genuine Toyota or a generic Blueprint bearing. Anything else I would suspect is made of finest Chinese chocolate Amen to that Don the rear lower most bolt for the north/south torsion bar is nearly always seized unless its been apart with someone that actually uses grease to lubricate on rebuild and the little 10mm bolts are always fun You won`t go wrong with the blueprint kits as other people have said but just be sure its installed via a press and not a hammer or it wont last long at all whatever the brand Martin |
