Charge cooler and spark plugs http://www.gt4dc.co.uk/forum/viewtopic.php?f=2&t=6914 |
Author: | seanyboy [ Thu Jan 23, 2014 8:49 am ] |
Post subject: | Charge cooler and spark plugs |
Hi guys possibly another daft question but I'm going to compression check my car and I was wondering if I can get to them without removing the charge cooler completely? If I do remove the charge cooler will I lose all my coolant? Thanks |
Author: | Nibbles [ Thu Jan 23, 2014 9:29 am ] |
Post subject: | Re: Charge cooler and spark plugs |
You should be able to leave. The pipes connected and lift through nearly 90 degrees to get access. |
Author: | Sirius [ Thu Jan 23, 2014 11:17 am ] |
Yep you will be able to leave in place, use a bit of wood to prop it up. If you remove it you'll lose coolant yes and it will get messy unless you drain it properly from the radiator. |
Author: | seanyboy [ Thu Jan 23, 2014 1:26 pm ] |
Thanks a lot guys |
