Rear suspension clunk http://www.gt4dc.co.uk/forum/viewtopic.php?f=2&t=6951 |
Author: | seanyboy [ Sat Feb 15, 2014 8:20 pm ] |
Post subject: | Rear suspension clunk |
Hi guys recently my car has developed a clunk which you can hear and feel in the car which I think is coming from the left rear suspension. It's fairly loud and can be felt every time. It mostly happens when first pulling away to drive or after reversing and when applying the brakes in reverse. I think it also happens when going over speed bumps but it's hard to tell if it's the same clunk or just my shot front control arms which I know need replaced. Anyone got any advice on this? Thanks for reading guys |
Author: | TrackToyFour [ Sat Feb 15, 2014 9:37 pm ] |
Post subject: | Re: Rear suspension clunk |
Have you checked the brake pads? They often make a 'clonk' noise under the circumstances you describe. Worth check to make sure you have all the P clips and backing pads fitted. |
Author: | Sirius [ Sat Feb 15, 2014 9:55 pm ] |
Also worth having a look at the rear anti-roll bar bushes and droplinks. |
Author: | seanyboy [ Sat Feb 15, 2014 10:07 pm ] |
I have a whiteline arb which was put on about a year ago so I hope the bushes and drop links will still be ok. These would have been replaced at the same time wouldn't they? I was thinking it might not actually be coming from the wheel and actually be the diff mount. Does that sound at all likely to yous? |
Author: | Sirius [ Sat Feb 15, 2014 10:11 pm ] |
The rear diff mount is a common cause of clunking and fortunately one of the cheaper fixes if it is the problem. The whiteline ARB comes with new bushes if you buy one new but not droplinks, usually they do get replaced as the old ones are a pain to get undone without destroying them but its possible they were not changed. Have a look around the diff area, its fairly easy to see if the mount is in poor condition. |
Author: | seanyboy [ Sat Feb 15, 2014 10:39 pm ] |
Thanks for the help mate il get on it tomorrow. Has anyone here ever repaired ther diff mount by filling with polyurethane? Iv heard of it being done and thaught I might aswell give it a try |
Author: | Nibbles [ Sat Feb 15, 2014 11:44 pm ] |
Mixer is now doing this and selling them. Diff mount is most likely fit to symptoms. Drop links and top mounts tend to be more bump related. |
Author: | TrackToyFour [ Sun Feb 16, 2014 12:39 am ] |
Does anyone have a picture of a knackered rear diff mount? Can you tell visually if it needs to be replaced or is it simply the rubber which becomes 'tired'? |
Author: | banzaibaz [ Sun Feb 16, 2014 8:22 am ] |
The rubber can become soft more elasticity as ive recently found on my doblo large gearbox mount clunking but looks ok or you can see it coming away from its metal body breaking up/cracking etc which causes excess movement. |
Author: | Meurz [ Sun Feb 16, 2014 8:19 pm ] |
It's easily spotted by the center part not being in the center (or attached at all) due to the rubber disintegrating over time. TrackToyFour wrote: Does anyone have a picture of a knackered rear diff mount? |
Author: | banzaibaz [ Sun Feb 16, 2014 8:23 pm ] |
Yep that ones defo had it. Sent from my iPhone using Tapatalk |
Author: | seanyboy [ Sun Feb 16, 2014 8:27 pm ] |
Lol well that should be easy enough to spot shouldn't it. I'm going to give rebuilding mine a try I think. Doesn't look too hard. Il let yous know how I get on. Thanks for the help |
Author: | TrackToyFour [ Mon Feb 17, 2014 1:23 am ] |
Haha, great pic! Should be easy to spot even for the untrained eye..... Maybe I should have said semi-knackered? |
