st205 clutch http://www.gt4dc.co.uk/forum/viewtopic.php?f=2&t=7373 |
Author: | johntaylor32 [ Tue May 12, 2015 8:00 am ] |
Post subject: | st205 clutch |
How do you bleed a standard clutch please? Biting point is nearly at bottom, no smell, no juddering, accelerates fine, |
Author: | niblettr [ Fri May 15, 2015 10:43 am ] |
Post subject: | Re: st205 clutch |
Adjust the biting point at the clutch pedal end? I had to do this once when I fitted an FX400 clutch. Biting point was too low to the floor. The clutch bleed nipple (clutch slave cyclinder) is just above the front central engine mount. (somewhere near or under the heat shield or turbo I think) Probably bleed and try first in case the fluid is all manky and black. |
Author: | asdrewq [ Fri May 15, 2015 2:55 pm ] |
You can reach the clutch bleed nipple once you have removed the turbo inlet pipe. |
