It is currently Sun Apr 28, 2024 7:16 pm
 Post subject: st205 clutch
PostPosted: Tue May 12, 2015 8:00 am
How do you bleed a standard clutch please?
Biting point is nearly at bottom, no smell, no juddering, accelerates fine,
 Post subject: Re: st205 clutch
PostPosted: Fri May 15, 2015 10:43 am
Adjust the biting point at the clutch pedal end? I had to do this once when I fitted an FX400 clutch. Biting point was too low to the floor.
The clutch bleed nipple (clutch slave cyclinder) is just above the front central engine mount. (somewhere near or under the heat shield or turbo I think)
Probably bleed and try first in case the fluid is all manky and black.
St205 WRC - Running sweet.
PostPosted: Fri May 15, 2015 2:55 pm
You can reach the clutch bleed nipple once you have removed the turbo inlet pipe.
Users browsing this forum: No registered users and 192 guests
