Changing Charge Cooler Coolant http://www.gt4dc.co.uk/forum/viewtopic.php?f=2&t=7454 |
Author: | Spam [ Wed Sep 09, 2015 4:30 pm ] |
Post subject: | Changing Charge Cooler Coolant |
Can anyone tell me if there is a guide on how to change the coolant for the st205 charge cooler. Have looked but cannot find. Thx Spam |
Author: | asdrewq [ Tue Sep 22, 2015 6:52 pm ] |
Post subject: | Re: Changing Charge Cooler Coolant |
- drain coolant (remove hose from pump. Remove nsf under tray to access) iirc there is also a drain bolt on the chargecooler radiator. - refill - the most important step - when the chargecooler appears full, start engine & blip the throttle. This will turn on the pump for 30 seconds & pull the level down. Quickly Refill it back up to max during this period & screw the cap back on. Do this & you will never get a low level code 54. This needs to be done on a stone cold engine, preferably a few days after you filled the system & have driven around a bit to ensure there are no air pockets. |
