It is currently Fri Apr 26, 2024 8:02 am
Post new topic Reply to topic  [ 77 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: Another project
PostPosted: Fri Sep 18, 2015 8:27 pm
Saw this on ebay last week and thought it was worth looking at, went up to Hartlepool a couple of times before handing over the cash
It doesnt start but has fired and turned over, the battery is duff so having to use a jump start pack at the minute.
It will keep me busy this winter :)
 Post subject: Re: Another project
PostPosted: Fri Sep 18, 2015 8:32 pm
Its not showing any fault codes in fact the engine management light doesnt come on at all
Turning the key just results in a rapid clicking which I cant tell if it a relay opening and closing or the starter motor, any thoughts
PostPosted: Fri Sep 18, 2015 8:40 pm
Low battery causing the starter motor to not engage would be my first guess, or bad connection.?
Sent from my SM-G928F using Tapatalk
[color=#000080]ST205 WRC 1994
Hybrid turbo
Apexi AVC-R
PostPosted: Fri Sep 18, 2015 10:05 pm
Rapid clicking = duff battery. A jump starter pack / jump leads won't provide enough current if the battery has gone open circuit.
No engine light = bulb removed, ECU or EFI fuse gone or ECU faulty / removed.
PostPosted: Fri Sep 18, 2015 11:11 pm
Thanks both, was leaning towards a new battery first
PostPosted: Fri Sep 18, 2015 11:12 pm
Best check the ecu and fuses as well then, thanks chris
PostPosted: Sat Sep 19, 2015 7:47 pm
PostPosted: Sat Sep 19, 2015 7:49 pm
PostPosted: Sat Sep 19, 2015 7:50 pm
Came with a few bonus parts
PostPosted: Sun Sep 20, 2015 8:53 pm
So, I have checked the distributor cap, rotor arm, plugs and leads and put a new battery on.
It fires and splutters and on 2 occasions has started for a few seconds before stalling due to low revs, I tightened up the throttle cable a little to lift the starting rpm and the car ran for a minute before cutting out as I slackened off the cable. I haven't been able to start it again although it does turn over and fire
Thoughts?
PostPosted: Sun Sep 20, 2015 10:08 pm
I would say the next step is to replace the engine light and check error codes.
Being a 185, I'd most suspect a hole / leak in the air plumbing, quite likely in the corrugated pipe from AFM to turbo.
PostPosted: Mon Sep 21, 2015 9:25 am
This may sound really daft!
The turbo / air intake pipe as mentioned above is knackered and is cracked / holed. Would that result in the inability to idle due to the AFM not picking up any air being drawn in?
PostPosted: Mon Sep 21, 2015 6:21 pm
Indeed it would.
Tank (/gaffer/duct) tape is a usable temporary 'get you home' bodge to prove a point.
PostPosted: Mon Sep 21, 2015 8:14 pm
A temp repair wont do for this one I dont think it more or less crumbled when I took it off
PostPosted: Thu Sep 24, 2015 8:38 pm
Well there is fuel getting through, I took the fuel supply pipe off the top of the fuel filter and it pumped fuel out when I turned it over
Users browsing this forum: No registered users and 29 guests
