It is currently Fri Apr 26, 2024 6:48 pm
Post new topic Reply to topic  [ 77 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Another project
PostPosted: Thu Jul 14, 2016 9:33 am
Its now on its original plate so no batty boy comments please (or hairdressers ones) lol
Ill keep you posted JP, first impressions are good.
I agree it would benefit from more adjustment of the steering wheel
PostPosted: Sat Nov 26, 2016 10:22 am
The car has been over at my parents since getting the Boxster and getting the 205 on the road so last weekend I brought it back and put it in the garage in order to start the renovation
Ill upload some photos shortly but photobucket is mucking me around this morning and I am unable to upload from laptop to my accout
PostPosted: Sat Nov 26, 2016 5:55 pm
I have created an album, hopefully. The first batch of pictures shows the condition as it went in to the garage
http://s61.photobucket.com/user/david_t ... ibrary/GVN
I have started stripping the car down and today the powder coating guy called round and picked up the subframe, suspension arms and a few brackets plus the wheels
PostPosted: Sat Nov 26, 2016 6:59 pm
sorry that some photos are duplicated in the album, photobucket is *bleep*.
Ill tidy things up next time I add new photos
PostPosted: Sat Dec 03, 2016 9:00 pm
the parts have come back from the powder coaters and have turned out really well
http://s61.photobucket.com/user/david_t ... v.jpg.html
http://s61.photobucket.com/user/david_t ... p.jpg.html
http://s61.photobucket.com/user/david_t ... a.jpg.html
http://s61.photobucket.com/user/david_t ... z.jpg.html
http://s61.photobucket.com/user/david_t ... t.jpg.html
http://s61.photobucket.com/user/david_t ... n.jpg.html
http://s61.photobucket.com/user/david_t ... e.jpg.html
PostPosted: Sat Dec 10, 2016 9:05 pm
The diff mount looked like it wouldnt last much longer so I enquired about a new / replacement mount and the prices are eye watering for a few simple pressed parts and a bit of rubber
I found a source of casting polyurathane with a little help from others and will give a home made approach a go
PostPosted: Sun Dec 18, 2016 6:13 pm
It took 2 goes as I wasnt happy with the first effort, the second one has turned out great though
PostPosted: Mon Jan 09, 2017 9:02 pm
De rusting of the underside has been going on for a few weeks and in the process I snagged the wire to the ABS sensor and pulled it out.
I was planning on removing the sensor to see if reconnecting is possible but the sensor isnt budging
Is there a special technique involved?
PostPosted: Mon Jan 09, 2017 9:10 pm
this is the one
PostPosted: Tue Jan 10, 2017 10:41 pm
Lots of penetrating fluid possibly a bit of careful heat?
I know these can be a real pain to get out.
PostPosted: Wed Jan 11, 2017 2:35 pm
Thanks, just being careful in case they screwed out on a left hand thread or something equally non intuitive lol
PostPosted: Wed Jan 11, 2017 8:09 pm
I have recently removed all 4 sensors to check them - recommend carefully applying constant gentle prising pressure with a screwdriver whilst also very slightly twisting forwards and backwards... got all 4 out without incident :P
The sensors are not screwed into the hub, they're a push fit held in place by the securing bolt you have depicted above.
Good luck!
PostPosted: Wed Jan 11, 2017 9:10 pm
Got it out Kris, thanks
Do we think this will repair / solder?
PostPosted: Thu Jan 12, 2017 7:28 am
No. Secondhand is probably your best answer :(
PostPosted: Wed Aug 15, 2018 8:49 pm
well a lot of water under the bridge since the last update
after a lot of effort, sanding, primer, sanding, painting, sanding, painting etc.... and finally compounding, polishing and reassembly
Users browsing this forum: No registered users and 32 guests
