It is currently Sat Apr 20, 2024 10:14 am
PostPosted: Tue Apr 18, 2017 4:01 pm
Hi There
I Need to change the power steering fluid on my ST205
Is there a guide to flush and change?
Spam
PostPosted: Tue Apr 18, 2017 6:44 pm
Everything is simple there.
Drained the old liquid - filled a new liquid.
e-mail vad07@inbox.ru
PostPosted: Tue Apr 18, 2017 11:16 pm
As far as I remember you 'bleed' the system by rotating the steering and topping up.
PostPosted: Wed Apr 19, 2017 12:12 pm
The best way is to use a 17mm spanner and undo the idle up control valve to drain the fluid. Refit then fill with fresh fluid. Turn the wheel with the engine on to bleed the system.
