It is currently Mon Jan 20, 2025 3:40 pm
 Post subject: avc-r not working
PostPosted: Sat Feb 03, 2024 2:01 pm
Hi my avc-r boost controller has stopped working for some reason
It powers up fine, but no display/readings?
any thoughts on this, is there a way to bench test it to get the display running to rule out
any other problems, any advise welcome
 Post subject: Re: avc-r not working
PostPosted: Sun Feb 11, 2024 9:47 pm
any thoughts at all? really need to try and fix this
PostPosted: Wed Feb 14, 2024 8:13 am
this forum doesn't see much traffic these days, most people seem to favour social media!
Regarding the avcr, from memory, it was quite a rare beast even back in the day.
I just did a quick online search...
https://www.google.com/search?q=apexi+a ... s-wiz-serp
Have a read through some of the posts...most common issues, broken wiring loom, have you lchecked for loose/damaged cables, or soemthing about grounding/earth...both grounds must be used, and both must be good quality groundings, again, check both.
Hope this helps.
Darryl
eastgt4
PostPosted: Tue Feb 27, 2024 4:44 pm
much apprecitated, know where your comeing from with regards to the use of socila media over forums
unfortunatly i dont use it so my options are limited
Ive also come to the conclussion after looking around that this is generally a (ground) issue
like you say at the loom end
dont think its a DIY for me, probably going to need it checked by a proper auto electrican to be sure
PostPosted: Wed Feb 28, 2024 12:15 am
I usually have a quick look on here every couple of weeks or so but, as above, very rare posts. Celica club UK is still a fairly active forum for quicker answers and much more likely to get a decent answer than on faceache.
Unfortunately I have no knowledge of the AVC-R. If you can post wiring diagrams from the handbook etc. I may be able to suggest more. Without that I can only suggest checking the 12V and the ground connections, i.e. make sure you have 12V on the wires going in to the unit. If it has 2 live feeds, e.g. permanent live for memory plus ignition live then check both are present. If it has power going in and no display then it's probably knackered.
PostPosted: Sun Mar 03, 2024 2:37 pm
yeah all posts ive read seem to lead to a ground issue at the Ecu end
as said probably best to get it checked by a auto electritian as im thinking
its probably going to need to be re-doing at the loom end
bit old school, but im leaning towards a dry joint that needs to be re-done
this type of thing is outside of my skill set as i dont really want to mess with the electrics
