pins for engine related electrical components / code 54 http://www.gt4dc.co.uk/forum/viewtopic.php?f=9&t=7556 |
Author: | Diceman [ Fri Feb 05, 2016 12:15 pm ] |
Post subject: | pins for engine related electrical components / code 54 |
I need to make up a couple of bridging wires for "Arsey" st185 RC 1) ac pipe pressure sensor has been removed and junked and I need to bridge two pins to stop the rad fans running constantly. Does anyone have any plug pins or know of a source. 2) code 54! Charge cooler has been removed and I'm getting code 54 as expected. I know I need to bridge the charge cooler level sensor, do I also need to install a pseudo charge cooler pump resistor on the 185? I'll need some pins for both if so! I know I can cut wires and splice them together but I'd rather leave the loom/connectors in good state for now. Long term I have a spare look and ecu that will be stripped of redundant wires so I'd like to keep the standard look as standard as possible. Any thoughts or comments welcome. |
Author: | Sirius [ Fri Feb 05, 2016 1:42 pm ] |
Post subject: | Re: pins for engine related electrical components / code 54 |
I have found this place useful in the past for that kind of stuff: http://www.bmotorsports.com/shop/ Most of the Toyota stuff is Sumitomo. |
Author: | Diceman [ Fri Feb 05, 2016 2:54 pm ] |
Cheers Mike, A good source of bits. I have found these guys who also do a range of Toyota plugs (just purchased some COP connectors from them):- http://www.shopbhp.com/collections/connectors?page=2 |
