It is currently Sun Jun 16, 2024 12:15 am
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 56  Next
PostPosted: Tue Sep 08, 2009 8:15 pm
Sunny wrote:
the maximum for the CT20B is 1,35bar (efficient) :)
Do you have any specification of this turbo ? I have one left ..maybe put it back on a nother mr2..
/ Dennis
ps sorry for writing in your thread about other stuff than your car :D
PostPosted: Tue Sep 08, 2009 8:22 pm
lol thats ok mate its all good to read
here is an upto daet lis of what i had dun to the car,
JDM ST185 353BHP 300FT/LBS AT 1.2BAR
MODIFICATIONS TO THE CAR
ENGINE MODIFICATIONS
 CYLINDER HEAD SKIMMED.
 VALVES RE-LAPPED.
 NEW VALVE STEM SEALS.
 BRAND NEW METAL 1.4MM HEADGASKET.
 HEAVY DUTY RACING SHELLS.
 FORGED 86.5mm CP PISTONS AND RINGS.
 FORGED ‘H’ BEAM RODS.
 BLOCK REBORED TO 86.5MM CLEANED & HONED.
 ARP FASTNERS.
 CRANKSHAFT REGROUND AND BALANCED.
 CT20 TURBO.
 FORGE ADJUSTABLE ACTUATOR.
 JUN 264CAM’s.
 JUN VALVE SPRINGS.
 HEAD PORT MATCHED AND POLISHED.
 PORT MATCHED AND POLISHED INLET MANIFOLED.
 PORT MATCHED AND POLISHED EXHAUST MANIFOLD.
 TRD THERMASTAT.
 MOCO 13 ROW OIL COOLER WITH RELOCATION KIT AND THERMOSTAT.
 HEAVY DUTY HKS TIMING BELT.
 HKS ADJUSTABLE CAM PULLEYS.
 540CC INJECTORS.
 WILBRO FUEL PUMP.
 HKS AIR FILTER.
 HKS F-CON V-PRO GOLD ECU.
 MAGNICORE HT LEADS.
 FULL 3” EXHAUST SYSTEM.
 3” DECAT.
 COLD AIR BOX.
 ELECTRIC SUPERCHARGER (FEEDING COLD AIR BOX)
 EVO VIII INTERCOOLER.
 2.5” INTERCOOLER PIPEWORK.
 HKS DUMP VALVE.
 BATTERY RELOCATION (IN BOOT).
 GROUNDING KIT.
DRIVE TRAIN MODIFICATIONS
 ST205 GEAR BOX.
 QUICK SHIFT.
 RPC 6 PADLE CLUTCH.
 D2 8-POT FRONT BRAKES WITH 330MM ROTORS.
 DRILL AND GROOVED READ DISK WITH RED EBC PADS.
 GOODRIDGE BRAIDED BRAKE HOSE.
 D2 RS COILOVER SYSTEM.
 POLYURETHANE ANTI ROLLBAR KIT FRONT AND REAR.
 POLY BUSH FRONT WISHBONES.
 POLY BUSH REAR SUBFRAME AND WISHBONES.
 BK 17” RACING ALLOYS.
 235/40/17 AVON ZZ3 TYRES.
INTERIOR
 EVO IV RECARO SEATS.
 52MM DIAMETER BOOST GAUGE.
 52MM DIAMETER OIL PRESSURE GAUGE.
 CHARGE TEMPERATURE GAUGE.
 AIR FILTER TEMPERATURE GAUGE.
 VISUAL PERFORMANCE PLASMA DIALS.
 BLITZ BOOST CONTROLLER.
 BLITZ TURBO TIMER.
 SPORTS STEERING WHEEL.
 SPORTS PEDALS.
ICE
 SONY MP3 HEAD UNIT.
 SONY 10 DISC CHANGER.
 350 WATT AMPLIFIER.
 500 WATT 10 INCH DIAMETER SUBWOOFER.
 PAIR OF REAR INFINITI GOLD 6.5 INCH ROUNDS.
EXTERIOR
 CARLOS SAINZ FRONT BUMBER
 RISING SUN GRAPHICS ON REAR ARCH.
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Wed Sep 09, 2009 8:49 pm
a few more pics of the wish bones with the polly bush's fitted read to go on the car :D
BRD Page
PostPosted: Sat Sep 12, 2009 9:53 am
You should notice a difference with those PU bushes up the front :)
PostPosted: Sat Sep 12, 2009 10:53 am
i will bo doing the same to the rear of the car and all the subframe :)
BRD Page
PostPosted: Sat Sep 12, 2009 11:26 am
I strongly recommend not touching the spherical bushes on the hubs...
PostPosted: Sat Sep 12, 2009 12:03 pm
witch are the spherical bushes mate? y do you not recommend doing them?
BRD Page
PostPosted: Sat Sep 12, 2009 1:12 pm
The spherical bushes look like this
They are fitted where the blue bushes are fitted in this hub...
The spherical type bushes are much harder than the PU bushes. Replacing these with PU means the hub moves about more and your handling suffers...
PostPosted: Sat Sep 12, 2009 3:48 pm
ok mate what would you say is best for me to fit?
thanks
BRD Page
PostPosted: Sat Sep 12, 2009 6:45 pm
IMHO stick with the spherical bushes. If worn replace with new. If not - leave the money in your pocket :-)
PostPosted: Sat Sep 12, 2009 7:32 pm
thanks for the addvice ill kep the stock spherical bushes and polly the rest :)
BRD Page
PostPosted: Sun Sep 13, 2009 12:12 am
Sounds like a good plan! Hurrah for car Clubs and forums! Lots of guys with GT4 experience lurk around forums! :P
PostPosted: Sun Sep 13, 2009 4:15 am
Indeed Kris is a master Lurker :-)
PostPosted: Thu Sep 17, 2009 9:02 pm
sum pics of my evo 4 recaro seats
a few pics of the das at night
BRD Page
PostPosted: Thu Sep 17, 2009 11:11 pm
how did you mount your seats? are you sitting much higher? I'm just going through this mess with fitting WRX seats in the st185 and its a mission which may require different bases.
Chur
GT Four Adovansu
Users browsing this forum: No registered users and 27 guests
