It is currently Sun Apr 28, 2024 10:42 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
PostPosted: Sat Nov 26, 2011 8:30 pm
Hi folks,
do anyone know the diameter measurement of the two cambelt idlers?
IDLER SUB-ASSY, TIMING BELT, NO.1 & IDLER SUB-ASSY, TIMING BELT, NO.2
http://www.toyodiy.com/parts/p_E_1995_T ... _1302.html
the problem is that i ordered them from a gen.4 which has a different part number against the gen.3, i will use the smaller gen3 oil pump gear and i doesn't want problems with the timing belt tension
possible anyone is curently building a gen.3 engine which can help me easily, thanks
PostPosted: Sun Nov 27, 2011 2:40 am
I can supply these pulleys... as per the cambelt replacement guide I wrote for both www.gt4dc.co.uk and www.gtfours.co.uk
PostPosted: Sun Nov 27, 2011 9:34 am
on my gen3 i have
gen3 oil pump gear
gen3 idler tim belt n2
gen4 idler tim belt n1
gen3 tim belt
everything is fine
PostPosted: Sun Nov 27, 2011 1:25 pm
sorry kris, i can't can find the diameter of the pulleys :(
merlin, thats good to know but to be sure and to safe money i'am in need of the measurements
geretz
PostPosted: Sun Nov 27, 2011 6:59 pm
i can get the dimensions tonight if I get out to the garage. Pretty busy at the moment.
GT Four Adovansu
PostPosted: Sun Nov 27, 2011 9:07 pm
thats great, there is no need to hurry but i'am glad if you can do me this once you find time :)
PostPosted: Fri Dec 02, 2011 5:44 pm
DeeCee, any updates for m? :)
PostPosted: Fri Dec 02, 2011 9:09 pm
sorry - i have been sick recently. Will update today for you after I run some errands this morning. Give me 3 hours
GT Four Adovansu
PostPosted: Fri Dec 02, 2011 11:40 pm
i'll give you more then 3 hours :lol:
i'am glad if you can spend some minuetes for me on the weekend :)
PostPosted: Sat Dec 03, 2011 9:37 pm
Right - sorry for the delay. Wobbly hands +/-.02mm
Top is new bearing, bottom two are old
Old on left, new on right
Old is 57.61mm diameter
Which is pretty much the same as the new
Width of bearing is 28.93mm
New bearings are model: 13503-63010
Hope this helps
GT Four Adovansu
PostPosted: Sat Dec 03, 2011 10:33 pm
big thank you 8)
my one has exact the same measurements
are you also possible to measure idler nr.1 ->
here are my measurements
60 x 29,6mm
PostPosted: Sun Dec 04, 2011 2:27 am
The bearings are both the same for the idler 1 and 2 for me. JDM ST205 1996
pic of idler 1
GT Four Adovansu
PostPosted: Sun Dec 04, 2011 12:15 pm
Hi DeeCee,
both gen.3 idler 1 & 2 had the same measurements of 57,6mm?
PostPosted: Sun Dec 04, 2011 6:25 pm
yes
GT Four Adovansu
PostPosted: Sun Dec 04, 2011 7:32 pm
here is the difference to find, thanks a lot DeeCee :)
Users browsing this forum: No registered users and 110 guests
