It is currently Thu May 02, 2024 12:09 pm
Post new topic Reply to topic  [ 166 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 12  Next
PostPosted: Sat Oct 29, 2011 3:30 pm
Well after reading another thread i too have decided on a electric water pump - so payday will be getting one.
The EWP115 with controller and also a Fuelab fuel filter
PostPosted: Tue Nov 01, 2011 9:10 pm
Had a nice shiny alloy electric water pump waiting for me when i got home :)
PostPosted: Wed Nov 02, 2011 12:04 am
hows the engine build getting on bud are all parts sourced at last, ive gone for still using the hks stroker kit inc 87mm pistons for my build
PostPosted: Wed Nov 02, 2011 8:13 am
Yeah all bits are either here or on order.
Build not started as TGT have others in front of me but no rush as its took 2 years to get to this stage
PostPosted: Tue Nov 22, 2011 8:58 pm
Well just sent roof lining , armrest , visors and door cards to be retrimmed in red alcantara :)
PostPosted: Mon Dec 19, 2011 9:41 am
As im taking my time with this build does anyone think a 1ZZ shimless bucket conversion is worthwhile??
Only ask as ive noticed that the fensport cars have this as well as a few others.
Also as i could not find a HKS twin power amp does anyone have any suggestions - what about something like this - msd ignition amplifier?
http://www.raceparts.co.uk/products/mot ... D+Ignition
PostPosted: Mon Dec 19, 2011 1:38 pm
I have done the 1ZZ-JGE(?) shimless bucket conversion for my 185.
The main reason for this is because I had heard that, on high powered 185's, there was a tendancy for the shim to try and escape (shim on bucket configuration).
This is not an issue on the 205 as it's a bucket over shim configutration.
I have an HKS Twin Power Ignition Amplifier for my build although I'm not 100% sure I'll be using it - I need to talk to my engine builder guru.
Also, seem to have found it here:
http://www.alamomotorsports.com/HKS/hks_tp.html
PostPosted: Mon Dec 19, 2011 4:03 pm
Cheers Nige :)
PostPosted: Thu Dec 22, 2011 7:34 pm
The shimless bucket conversion is not really worth doing unless you are planning to track and/or compete with your car. Adrian, Nige and I fit that description ;-) In my case I have fitted the o/s valves as well. I'm a great believer in letting the engine breathe as freely as possible, even with a turbo!
PostPosted: Thu Dec 22, 2011 7:43 pm
DITTO...1mm oversize inlet and exhaust Ferrea valves with HKS springs etc.
PostPosted: Thu Dec 22, 2011 8:08 pm
Will be doing some track days but not going down shimless bucket road.
I too have 1mm o/s valves ect.
PostPosted: Fri Dec 23, 2011 2:58 pm
big valves can couse problems on more valve engines, in worst case
the intake flow of valve one affect the intake flow of valve two, and this can couse less filling
but i think this is not a problem on our engines, a lot of dyno sheets show that it works :)
PostPosted: Fri Dec 30, 2011 11:34 am
Does anyone have any recommendations on fuel filters for my build??
Would you use a 2 filter set up or just the one??
PostPosted: Fri Dec 30, 2011 11:56 am
I am pretty sure JEMS have fitted two fuel filters to my tracktoy.
One decent fuel filter should be more than adequate.
I would imagine that, like everything else, you need to take into consideration the diameter of the fuel lines and the fuel pump that you are running.
I haven't looked into which one yet.
A few pointers:
http://racingarticles.com/article_racing-68.html
http://www.circletrack.com/enginetech/ctrp_1012_racing_fuel_filters/index.html
http://atspeedracing.co.uk/products/index.php?main_page=product_info&cPath=8_71&products_id=225&zenid=c8e13b90679ae9c70b1072a8c9ac7d43
