It is currently Sun Apr 28, 2024 5:36 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jan 22, 2006 11:54 am
Kris wrote:
You will be lucky to get the little tinker off! I managed a couple of times and the last one required a grinder...
Hmm....that sounds like fun Kris :roll: I can just imagine the language :twisted:
PostPosted: Sun Jan 22, 2006 11:28 pm
Was probably like a bunch of adolescents watching Baywatch "oh please come off, oh please come off"
PostPosted: Mon Jan 23, 2006 12:10 am
Hmm,
I'm not sure I've got any tinkers lol
Although I did see a pikey camp while cycling earlier. Perhaps they'll do instead :lol:
Also going to have to invent some sort of press to refit the new. Did it really take all 10 tons Kris. I'm thinking of a threaded rod through the hub and screw it back in as it were
PostPosted: Mon Jan 23, 2006 6:24 pm
Steve - you will not be able to get the bearing in or out using a vice or a threaded bar arranagement.
If you plan on DIY then you could always get a garage to do the "press" bit?
I can show you the metal plate ~10mm I bent pushing these damn things in and out...but maybe I've just been "lucky" again! :lol:
PostPosted: Mon Jan 23, 2006 6:47 pm
All photos greatfully received!
I do have a man with a press so I might be paying a visit by the sounds lol
PostPosted: Tue Jan 24, 2006 8:49 pm
**update**
I found the problem lol
The hub nut was finger tight :shock: (what [expletives deleted] kind of size is a 30mm deep socket anyway)
The wheelbearing has clearly been changed in the past so either it wasn't tightened or the bearing was not sitting correctly on the stub axle
However, I was unwilling to just tighten it up thinking that there could be bearing damage.
So apart it has all come. Took quite a lot of [several pages of expletives deleted to prevent swear filter overload] to get the hub carrier off the most difficult part being the [more deletion lol] ABS sensor which was well seized in, but off it now is.
Both bearing races removed leaving me to press out/in the main shell tomorrow and re-assembley
PS
Now it's all apart it's obvious that the bearing is in perfect condition :(
I assume the clicking noise was either brake pads into the grooved disck or movement in the axle splines. No signs of damage on the shaft though phew
PostPosted: Tue Jan 24, 2006 10:42 pm
Isn't the hub nut done up and then a split pin and cap shoved on?
PostPosted: Tue Jan 24, 2006 10:59 pm
Yep, the hub nut should have the hex retainer shell and split pin to stop it coming loose. Checked this on the EPC just to confirm :wink:
Were these missing Steve?
PostPosted: Tue Jan 24, 2006 11:13 pm
Nope. Both present and correct which is what's strange
So it either wasn't torqued or one of the bearing races moved
PostPosted: Thu Jan 26, 2006 3:35 pm
Today's joy
Inner race fixed to the shaft with Loctite 648 bearing retainer compound
Here's hoping for the best
All torqued up to 100lbf to hold the race in the correct position on the stub shaft.
It's one way from here. The loctite is semi-permanent requiring 200decC heat before the inner race can be removed from the shaft :shock:
PostPosted: Thu Jan 26, 2006 9:58 pm
Reckon you'll have it all done and dusted for Saturday eve? :wink:
PostPosted: Thu Jan 26, 2006 11:23 pm
Should be back together tomorrow
Providing I've picked the right loctite to stop the race spinning on the damaged shaft then it will be there saturday
I've currently got the whole assembley in the airing cupboard for 12 hours of 15 degC curing lol. There's a few raised eyebrows round here at the moment
PostPosted: Fri Jan 27, 2006 12:10 am
Excellent news! Look forward to you swelling the ranks.
PostPosted: Fri Jan 27, 2006 6:22 pm
Woot
Loctite for teh win
Back in one rotating piece now 8) :D :D :D 8)
PostPosted: Fri Jan 27, 2006 11:33 pm
Good result then Steve. No need to hide the Fraud behind a hedge this weekend :lol:
Users browsing this forum: No registered users and 167 guests
