It is currently Sun Apr 28, 2024 5:19 pm
PostPosted: Sun Feb 19, 2012 1:30 pm
Hi im new to the forum and have recently purchased a blitz spec s boost controller. for some reason its over boosting. does anyone have any idea as to why this is? pics would be very helpful thanks. it seems to do it when i gear down and push on the accelerator or when im cruising in any gear and put my foot down. i have the gain set down on 3 and 5 percent boost. Many thanks
PostPosted: Sun Feb 19, 2012 6:43 pm
A bit more information would be helpful. When you say you are overboosting what boost figures are you seeing? I used to run a Blitz DSBC Spec R and found the instructions on this link very helpful http://www.rtec.ch/dsbc_manual.html
I can't recall exactly what gain and volume I ran but the 3 and 5 you mention do seem pretty low. If you have replaced the cat with a free flowing downpipe then this will make a big difference and it will make it easier to overboost, particularly if you give the throttle lots of welly!
PostPosted: Sun Feb 19, 2012 7:37 pm
you just have gain to adjust on the BC? or is there also a set?
3-5 is very low which means nearly no boost controll, makes me think of a air leak anywhere to the acutator of the turbo or possible wrong lines on the boost selenoid (there is a in and out port!)
do you closed the line to the oem boost selenoid aka VSV?
PostPosted: Sun Feb 19, 2012 8:08 pm
for reference the gain i ave set ( for overall boost response or whatever on the blitz manual it recommends 5.. for the gain for each individual setting i ran 56 on setting 3 and 60 on setting 4 and these acheive around 1.1 - 1.2 bar
PostPosted: Sun Feb 19, 2012 9:34 pm
www.gtfours.co.uk > downloads
There is a guide on how to setup the Blitz DSBC there...
I too have seen/set a very low gain on to achieve a decent boost level and system response...
PostPosted: Mon Feb 20, 2012 9:11 pm
thanks for all the replys and manuals. finally got it sorted. had an air leak on one of my vacuum hoses and hadnt blocked off the vsv. now its at a staedy boost. set at 5 and 20percent reaching 0.90 hkpa
PostPosted: Mon Feb 20, 2012 9:59 pm
Result! ..... nice to hear you got it sorted :D
PostPosted: Mon Feb 20, 2012 11:03 pm
nice to hear too :)
Users browsing this forum: No registered users and 119 guests
