It is currently Mon May 06, 2024 9:37 pm
PostPosted: Mon Sep 24, 2012 12:39 am
As per title. Would it be a straight swap over or is it not even worth the hassle? Just that I heard the st205 'box is stronger in 3rd and 4th gear
PostPosted: Mon Sep 24, 2012 9:22 am
its a pretty straight swap to be honest, a few things need changed such as the speed sensor and mounts. Few extra synchros make it a stronger box and they tend to be lower mileage too
ive got an 205 box from the 185 project which is ready to go if your interested. send me a pm
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Mon Sep 24, 2012 10:18 am
Off the top of my head, the 205 has better synchros in 1st and 2nd.
Gearing is a bit different too.
Otherwise, straight swap as above.
PostPosted: Mon Sep 24, 2012 8:08 pm
Fair play! I think it's only the transfer box (one right under the front seats) that needs replacing am getting a bit of a bang when changing gear sometimes... could be backfire as I have a straight through exhaust though lol
PostPosted: Mon Sep 24, 2012 8:10 pm
its not your rear diff mount is it? Is it real bad under heavy acceleration/gear changes?
PostPosted: Mon Sep 24, 2012 11:03 pm
Not really bad, in fact it's quite sporadic so not sure what it actually is... if you weren't in scotland would swing by and show ya what I mean lol
PostPosted: Mon Sep 24, 2012 11:41 pm
If it's a thump from the back it's probably diff mount.
Gearbox/transfer failures are rare apart from synchro wear (crunching into gear).
PostPosted: Mon Sep 24, 2012 11:59 pm
How much do diff mounts tend to go for? Sounds like a cheaper and easier possibility that could be transferred if it doesn't solve the problem
PostPosted: Tue Sep 25, 2012 12:21 pm
http://www.tcbparts.co.uk/
Suspension section.
Rear Differential Cushion Mount Genuine Toyota
Celica ST 205 GT4
& ST 185 GT4, ST 165 GT4
Part number: 52291-20010
Special Offer Price: £79.36 + vat each while stock last
PostPosted: Tue Sep 25, 2012 12:33 pm
sounds a little gettho but I filled the 185 rear diff mount rubber with polyeurathene silicone and it hasn't knocked since. Cost around £8 a tube
PostPosted: Tue Sep 25, 2012 5:03 pm
lol got a picture?
PostPosted: Tue Sep 25, 2012 5:58 pm
I did similar on the one on my 205, except I used some expanding foam we use on parts of our electric vehicles.
In my case the rubber was ok but had become detached from the outer so I just filled all the voids.
A really knackered one would require a jig/mould to be made and then remove all the rubber & pour in new of the correct hardness.
PostPosted: Thu Sep 27, 2012 8:22 pm
Ok but I am not entirely sure what I'm supposed to be looking for/at?
PostPosted: Thu Jul 11, 2013 8:13 am
Hi, can someone point me in the right direction as to what rubber/silicone I could buy to re-do a rear diff mount. I'd like to go down the rout of doing the whole rubber (remove all the old stuff...) please :)
St205 WRC - Running sweet.
PostPosted: Thu Jul 11, 2013 8:22 am
My mate woosh has just completed a rear diff mount using some rubber stuff, not sure if he's put it on a tgread yet but give him a pm. He's on here and the oc. :smile:
Sent from my GT-N7100 using Tapatalk 2
White 1990 GT Four ST185 (Import)
Now with 205 engine, ecu, engine & internal loom inc Speedo binacle and heater control.
