It is currently Sat Apr 27, 2024 12:00 pm
 Post subject: standard brake size help
PostPosted: Mon Apr 22, 2013 9:25 pm
Hi, did a quick search and found plenty of brake upgrade topics but couldn't find what diameter discs I need for the front of my st185. When I built the car I had some JDM brakes and some smaller UK abs model brakes. I had to fit the smaller 2 pot calipers and discs due to condition and I am now trying to buy new discs for them. They are in a bad state and measure about 255mm diam.what size (when new) do I need to get. So far I can only find 275mm discs are they the larger JDM ones or have mine really worn that much?
Thanks in advance!
PostPosted: Fri Apr 26, 2013 2:36 pm
Car Model: ST165
Early (pre August 1991) JDM ST185 with twin pot floating caliper use the same front disc and caliper as the ST165: 25mm x 255mm.
The UK and late spec JDM ST185 & ST182 with the single pot floating caliper use the 25mm x 277mm front discs.
ST165 turbo 4WD
PostPosted: Fri Apr 26, 2013 8:37 pm
Thank you. That's answered all my questions I've come up with from trying to source the right ones.
Users browsing this forum: No registered users and 81 guests
