It is currently Sun May 12, 2024 2:34 am
PostPosted: Mon Jun 03, 2013 10:38 am
Does anyone have any idea how much torque can our entire drive train take before giving out?
I mean "assuming" I have an engine producing a ridicules amount of torque. What what would go first and how much can it take?
Talking about the ST205 btw.
Thanks
PostPosted: Mon Jun 03, 2013 4:46 pm
i would guess the cluth, and this is good, my seight of things is pretty simple, i preffer a damaged cluth then a transmission
thats why i am not using a cluth which handels 700NM, my target was 500NM and the cluth is able to handle a little more then this 550NM iirc
i would not drive more then 500NM, anywhere here is the boarder line i think
PostPosted: Tue Jun 04, 2013 11:27 am
Sunny thanks for that info.
PostPosted: Tue Jun 04, 2013 12:57 pm
Id say rear diff / clutch would be first to break.
Gearbox / shafts are actually pretty strong..
PostPosted: Tue Jun 04, 2013 4:27 pm
I know fensport had some recurring problems with selector forks breaking inside the box at high power.
PostPosted: Tue Jun 04, 2013 4:57 pm
I would suspect selector fork problems to be down to banging it through gears quickly rather than power / torque related. It does seem to be a weak point in these gearboxes when animals are driving :lol:
PostPosted: Tue Jun 04, 2013 5:19 pm
^^^^^ pmsl he's never going to forget about it :)
PostPosted: Tue Jun 04, 2013 6:01 pm
Did you break one ? I've forgotten.
PostPosted: Tue Jun 04, 2013 6:52 pm
When Adrian ran the Corolla RUNX on the drag strips he used to take spare drive shafts and rear diffs. I recall he broke either a DS or a Torsen rear diff at Santa Pod. The 3S-GTE was putting out around 500bhp. Later on I think he set up the MoTeC launch control to take the strain off the transmission.
PostPosted: Tue Jun 04, 2013 9:43 pm
I thought the selector forks failing were suspected to be an issue caused by the fancy gearbox or selector he was using?
PostPosted: Wed Jun 05, 2013 12:40 am
He used three different type of gearboxes in the Gen 7 Celica, OEM followed by Elite and Pfitzner dog boxes. You are right that he had some bespoke steel gear selectors made up for the Elite box after the OEM selectors failed.
PostPosted: Thu Jun 06, 2013 12:42 pm
so the forks in the stock gear box. Assuming they mainly break from gear change with huge power rite? What if it was just in 1 gear and a lot of power was put through? The rear diff's the next problem then?
PostPosted: Thu Jun 06, 2013 4:09 pm
The fork breakage is not related directly to power
The issues Adrian had were a side effect of the straight cut gear cluster (and possibly the sequential shifter but I think that came later) used to more effectively deploy said power. I do remember him breaking a couple of diffs and iirc a trip to the dragstrip saw a driveshaft or two in the support vehicle
PostPosted: Thu Jun 06, 2013 6:42 pm
The stress on the selector forks is down to the arm muscles of the driver, not the pony muscles of the engine.
PostPosted: Fri Jun 07, 2013 11:22 am
So has anyone ever upgraded the rear diffs then? What options do we have? Is it possible to install a strong ford 9" rear diff? Props and shafts custom made I know.
