It is currently Tue May 21, 2024 2:31 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 30, 31, 32, 33, 34, 35, 36, 37  Next
 Post subject: Re: Project Taurus
PostPosted: Sat Jun 22, 2013 2:52 pm
yesterday, anything is missing
today, here it is
bin von der kupplung erstmal überrascht da die pedalkraft wie oem ist, bin mal auf den das verhalten gespannt ob ein/aus verhalten oder ob schleifende kupplung auch möglich ist
some small bits are missing, next week comes the downpipe
PostPosted: Tue Jul 02, 2013 11:17 am
it goes on
PostPosted: Tue Jul 02, 2013 4:46 pm
Looking really nice Sunny! :D
PostPosted: Wed Jul 03, 2013 10:31 pm
thanks, next step is a custom oil catch can and in two weeks it we activate the engine......or de-activat him :mrgreen:
depenting how clean i worked :lol:
PostPosted: Thu Jul 11, 2013 6:49 pm
48hours left until the deadline, i shall i call it judgment day :D
PostPosted: Fri Jul 12, 2013 10:44 pm
less then 24hours left, is it the phoenix out of the ashes or thousend of euros scrap metal
.....we'll see
PostPosted: Sat Jul 13, 2013 3:20 am
Hope it all goes well :)
GT Four Adovansu
PostPosted: Sat Jul 13, 2013 4:34 pm
I really hope it all went well!
PostPosted: Sat Jul 13, 2013 10:04 pm
......tumbleweed? :lol:
PostPosted: Sun Jul 14, 2013 3:42 am
He probably went to sleep after he turned it over.
"right, engine starts, once around the block, grab a shower and hit the sack for work tomorrow.."
GT Four Adovansu
PostPosted: Sun Jul 14, 2013 4:06 pm
Hi folks,
thanks a lot for all that wishes 8)
buuuuuut......we where not able to set the ignition without a ignition timing pistol,
missed to mount the engine - wire on the backsinde of the intake manifold, the hell no space ~1h of work
we used the haltech connectors without loom in them, a pain of work
we found that the cam and crank position wiring is not the same as on the plan and on all haltech ecu's, we was in need to
change the pins against each other
and at least we found that the ignition pistol has a brocken light
the pheonix is still fighting with the ashes, hope for a activation the next few weeks
da*n, i want to hear the engine sound, and drive them :lol:
Don, the cops are working, but with the cam and crank issue we had a lot adjustment to do, but one running i'am glad to gave you
all information, possible it is easier if i sent you the total mapping for all informations....once running
PostPosted: Sun Jul 14, 2013 11:13 pm
This is just the sort of real-life info that is invaluable so I shall wish you good luck with sorting out the details soon. I should get my COP kit in the next week or so then we need to work out how to splice it into the new loom!
PostPosted: Mon Jul 15, 2013 11:20 am
Hi Don,
do you use the oem wirring tree or a custom one?
a further problem was to get a signalt to the oem rpm cluster, i decided to use that wiring included to a male and female connector
(used all four cops)
but currently i'am not sure about it works
PostPosted: Mon Jul 15, 2013 4:48 pm
I'm guessing your information is running in wasted spark mode even though you have individual COP ? (i.e. cop 1 & 4 fed together and 2 & 3)
The standard rev counter will expect 1 pulse per spark, so if running individual spark drives you would need a diode from each COP feed.
PostPosted: Mon Jul 15, 2013 10:41 pm
that was also my thinking,
i connected all four cops to diods and then to the zener, i just hope it works :)
