It is currently Thu Apr 25, 2024 12:02 pm
Post new topic Reply to topic  [ 142 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 10  Next
PostPosted: Mon May 13, 2013 11:49 am
This looks amazing! Really looking forward to more updates on this project!
Did you buy the car as a runner and turn it into a project afterwards or was it bought as a project from the get-go?
I presume the 3SGTE is fairly responsive on ITBs provided the whole system is port matched etc as you've said... You're giving me ideas. Expensive ideas! :D
Matt
Currently planning an ST205 track & weekend build
PostPosted: Sat May 25, 2013 11:28 am
Thank you. The car was bought with a blown engine, to which I replaced the engine with a big standard one and drove rind for about a year in it. I only took it off the road for a service and McPherson conversion. Lol
That's the idea behind the itbs but I'm doin a few other obe off mods with it so I won't really be able to tell whatnot is that's giving me the gains.
5s Block almost finished prepping and ready to build.
PostPosted: Sun Jul 21, 2013 12:46 pm
Breather baffle and squirt jets fitted
Breather and water feeds
Slow progress as I'm still waiting for rods
Old turbo and wastegate vs new turbo and wastegate. Need to get a custom vband manifold when funds allow in the future :/
PostPosted: Sun Jul 21, 2013 5:05 pm
Are you going to fit a water manifold. Really interesting work
Also are you a journalist? Faced with a burning car I'd be going for a fire extinguisher while I still had eyebrows, not reaching for a camera to tweet what happened to them :lol:
PostPosted: Sun Jul 21, 2013 5:31 pm
There was no taps or water or extinguishers about for miles. I watched it burn for about 20seconds before I took the pic. It was only brake cleaner by accident almost took my eyebrows off. The roar when it went up scared me more.
I will make a water manifold to suit but still wondering where to take the turbo water feed off before I do as there isn't a thermostat so its one flow and not two as a normal mechanical pump setup has. Have either the option of feeding it water from the water pump or after its been heated through the engine like a standard 3s.
PostPosted: Sun Jul 21, 2013 11:48 pm
I'd love to know how the coolant flows through the block with this setup! You going for a closed deck?
PostPosted: Sun Jul 28, 2013 4:46 pm
I did have a toyota coolant flow diagram that shows the flowu. Dont know where thats gone tho :/. The exhaust side, if u look at an own gasket has bigger holes than the inlet side. Also was contemplating on running a water bypass on the back of the block like the rev 2s but decided not to as rev 3 onwards don't.
Image dummy mock up of head and a pulsar plenum.... I the process of making a thinner plenum for clearance.
PostPosted: Sun Aug 25, 2013 2:03 pm
PostPosted: Sun Aug 25, 2013 2:09 pm
3rd great synchro and baulkring replaced as the box used to crunch during spirited driving.
The rest of the box stripped, cleaned and assessed for wear and tear. All seals replaced.
Surprised at the cost difference of 2nd and 3rd gear baulk rings ring. 2nd gear is £25, 3rd is £140 give or take a few pounds :/
PostPosted: Sun Aug 25, 2013 5:41 pm
Really interesting pictures. :)
PostPosted: Tue Aug 27, 2013 10:51 pm
Very interesting and great details.
PostPosted: Wed Aug 28, 2013 7:44 am
superb, keep us updated and loving all the photos!
PostPosted: Thu Oct 31, 2013 2:41 pm
PostPosted: Thu Oct 31, 2013 3:12 pm
Awesome! Keep the pics coming :) I love the 5S-GTE sticker! What coating did you use on the block?
Matt
PostPosted: Thu Oct 31, 2013 5:25 pm
Thanks for the comments.
Was debating on using a 4sgte as there is t one in existence just to add confusion.
Coating, if u mean paint then its daihatsu gun metal great paint.
Can see the rod length and piston height differences in the pictures. Squish is at around 0.7 mm on a standard 3sgte gasket. Cams have been zeroed in at 103/106 bit with plenty of valve to piston clearance. Bit wild I know but should still idle ok. Gives a compression Ratio of just over 9.2:1.
Will collect some more dust now will I save for other non car bits. Car has been moved into the new unit. Much more space :)Image
Users browsing this forum: No registered users and 42 guests
