It is currently Wed May 22, 2024 12:17 am
 Post subject: hissing sound
PostPosted: Fri Sep 27, 2013 12:40 pm
hi guys,just done a service on my car last night,started the car for a sec to get new oil round and as I stoped the engine I could hear a hissing sound coming fronm the brake master cylinder area,the hissing stops shortly after the car is switched off,is the cylinder gone?. :(
cheers in advance.
 Post subject: Re: hissing sound
PostPosted: Fri Sep 27, 2013 1:15 pm
Sounds like the servo, check the pipe from it to the intake manifold for leaks.
Sent from my GT-N7100 using Tapatalk 2
White 1990 GT Four ST185 (Import)
Now with 205 engine, ecu, engine & internal loom inc Speedo binacle and heater control.
PostPosted: Fri Sep 27, 2013 1:26 pm
il check that when i get home,cheers mate
PostPosted: Fri Sep 27, 2013 2:19 pm
Try the brake pedal after the hissing stops to see it it still has air in the servo.
PostPosted: Fri Sep 27, 2013 3:17 pm
Could also be a leaky one way valve or a perished seal
PostPosted: Fri Sep 27, 2013 6:37 pm
I tried the brake with the engine running couldn't hear any noise, brake pedal felt ok only thing I noticed was the fluid raised slightly when I braked,couldent see any dodgy hoses,theres no fluid leaking anywhere inside the car or engine bay, the noise dose seem to be coming from bottom area of the cylinder/reservoir.
can it be refurbed with a kit?
will it pass my MOT sat like this?.
cheers guys
PostPosted: Fri Sep 27, 2013 6:56 pm
Switch off engine
Wait til hissing stops
Then try the brakes. A solid pedal first pump indicates a leak in the servo but it will always go hard after a few pumps
If it does lose pressure then more tests are required to find the fault
PostPosted: Fri Sep 27, 2013 7:02 pm
I did try the brakes after the hissing stopped pedal wasent rock hard,like you said it needs a few pumps to get really hard
is the rebuild kit on tcb the one that overhauls the whole unit?
PostPosted: Sat Sep 28, 2013 6:01 pm
The tcb unit is a master cylinder kit. Afaik the servo isn't rebuildable but if you're not experiencing any issues I wouldn't go making trouble anyway
PostPosted: Sun Sep 29, 2013 12:10 am
Didn't Mike have his servo rebuilt?
PostPosted: Sun Sep 29, 2013 1:22 am
Nope - there is no kit available, I rebuilt just the master cylinder.
A new servo from Toyota is fearsomely expensive, there wasn't anything wrong with mine so I left it alone.
PostPosted: Sun Sep 29, 2013 5:01 pm
Could it be a vac leak around the inlet manifold area ?
2004 Subaru WRX
PostPosted: Tue Oct 01, 2013 12:47 pm
well it passed MOT with only a bulb in the number plate gone lol.
