It is currently Sun May 05, 2024 4:58 pm
 Post subject: code 42
PostPosted: Sun Nov 03, 2013 5:04 pm
hi all. I've been getting a code 42 code as you know. I've changed the speed sensor but still getting the bloody code. speedo is working fine and doesn't seem to miss a beat. could it be a faulty converter on back of the dash of do I have bigger gremlins? any advice or suggestions greatly received...
gav
 Post subject: Re: code 42
PostPosted: Sun Nov 03, 2013 5:12 pm
Unless you are sitting for 10 seconds just revving in neutral I'd suspect the converter
PostPosted: Sun Nov 03, 2013 7:47 pm
lol. don't do staying still. speedo its self works but maybe its the signsl out. ebay it is then to get another.
PostPosted: Sun Nov 03, 2013 8:59 pm
On a 205 the signal goes from sensor to dash then out of the dash to the ECU.
If you have the converter before the speedo and the speedo works then it isn't the converter.
It is possible the converter is between dash and ECU to remove the speed limit, but then I'd expect the speedo to read in KMH unless it's had an alternative face fitted.
PostPosted: Mon Nov 04, 2013 12:13 am
standard face with the k blacked out. could it be a broken wire between the converter and the ecu? this car it's killing me. l
PostPosted: Mon Nov 04, 2013 9:33 am
It's pretty common for converters to include a speed limit remover too meaning the Speedo drive and ecu drive are different. There's also the possibility of a stand alone speed limit remover.
Need. To do some poking about
PostPosted: Tue Nov 05, 2013 1:26 am
think I found the problem this evening. got the ecu and f com ecu out and found a broken black and yellow wire. couldn't trace it but re joined it. only driven it 4 miles since but nothing came on. so fingers crossed. I will keepyou all informed.
PostPosted: Tue Nov 05, 2013 9:52 pm
so far so good. took the beast out tonight and had a bit of a run, gf wasnt to happy tho. but on a better note no eml or abs light.. i think its sorted. time will tell
PostPosted: Thu Nov 07, 2013 11:11 pm
damn it, the eml came on again at 80mph. will have a look tomorrow and see whats what... any other ideas?
