It is currently Sat Apr 27, 2024 9:43 am
Post new topic Reply to topic  [ 98 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7
 Post subject: Re: ST165 project ...
PostPosted: Fri Jul 04, 2014 12:31 pm
Been jumping about a little bit but mainly electrics ...
Car wouldn't start for a while but doing some checks I found the ignitor wire had broken and so that was an easy fix in the end. It allowed me to validate the installation of the ST205 ECU and wiring but as it was Paul Bartolo that did it (some may remember him) I didn't have any worried as it was a superb job ... Reading so many articles on how others had done it I can see Paul took his own approach ...
I tidied up the loom a bit to remove redundant wires and to get my head round where everything went, what sensors I have and where they go to the dash etc. all in readiness to install the stack dash and warning light cluster I have.
Also I had bought a Coralba trip computer which needed wiring up as it came without a harness, these are normally £150 but I made one up after finding the wiring pin-out which is VERY hard to get hold of - probably for the reason you can make a cable up yourself for a couple of quid !!! I have a 3 wire speed sensor (and various others) so that should be OK too ...
Finally I have started to install the stack dash which looks very easy due to the loom being fully self contained. I will now not splice into the main loom to pick up sensor inputs but rather use the full stack look to pickup from the engine sensors - this way both wiring systems can remain independent ...
Some pics then for anyone following ...
My trip computer (this is the c-trip not the c-rally but it's basically the same apart from the fuel being replaced with temperature - oh and the price !!!)
The authentic trip computer from a works car ...
Stack dash panel trial fit and switches ...
Warning light panel off a motorbike of all things £10 e-bay ...
My work area !
Ecu wiring tidied up ...
Oh I made these panels to go around the front cage legs to make the dash look neater ... Foam and alloy versions ...
Current cars
ST185 RC (daily driver)
ST165 (project)
Previous GT4's
ST205 WRC #2082 - (sold)
ST185 CS #2682 (sold)
ST165 (sold)
ST185 CS #2867 (RIP)
Website
http://www.k1ano.co.uk/
:infinity:
PostPosted: Wed Jul 09, 2014 12:02 pm
Well I didn't realise how much the JDM wiring is different from the UK so it was a good job I had all the workshop and coloured wiring manuals ...
After thinning out the wiring loom, the warning light panel worked out OK, I decided to wire the N upto the brake warnings ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Wed Jul 09, 2014 8:56 pm
Paul Bartolo in did it my way shocker :lol:
Great work going on Martin, keep it up
PostPosted: Thu Jul 10, 2014 12:49 pm
Little bit more tidying of wires and connecting up the dash ...
And some more fittings for fuel and oil pressure ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Thu Jul 10, 2014 10:58 pm
Good work Martin. The multi-coloured wiring loom spaghetti looks a bit scary. Like the 1988 retro look with the old-skool oil pressure sensor!
PostPosted: Fri Jul 11, 2014 12:08 pm
Thanks Don ...
The amount of wiring (and colouring) is astonishing even in a 1987 car ! .. and the JDM wiring is different from the UK spec so my workshop manuals and wiring diagrams are not quite the same so a bit of testing and intuition is involved.
I have tried to remove as much redundant wiring as possible safely but didn't want to remove the whole cabin/engine loom and connection boxes to perform a complete purge of ABS/air-con/ancillary systems - this would take too long and to some extent is not necessary. I did consider making a complete loom but that would be prohibitively time consuming for the benefit I will get. I do like the challenge of integrating things so am fairly comfortable with this and 'tapping' into the existing wiring and systems and making whatever extensions I need - on a purely amatuer basis though ... To install the STACK dash I am retaining the OEM dash connectors, rather than butcher them and make new ones - which would have been tidier, in case I ever want to re-instate the OEM dash as the ST165 dash is superb in its own right ...
You have the superb unenviable luxury of being able to make/commission a bespoke loom for your track car with the minimum of wiring and am sure it will be great - I am following your project with interest having only recently discovered it !!
M
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Tue Jul 15, 2014 12:18 pm
Pretty much done with the Stack dash install now, maybe I can start to think about re-assembly !!
Cut a slot for the warning light panel and alarm light fitted ...
Some fettling to clear the cabling ...
With and without cowling ...
Trim refitted and existing switch cut-outs used for the 4 stack switches ...
Some final pictures with the steering wheel test fitted ...
Some more gauges received from the states which I might install separately (not the 4k rev counter though LOL) with separate starter switch ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
PostPosted: Wed Sep 17, 2014 12:52 pm
Next updated ...
I purchased some Teins off Warner which had been unused, apart from on a rolling shell, but some of the paint had flaked off so I decided to try and re-furb the paint ...
As purchased, essentially new but I wanted to clean them up a bit - this wasn't essential but I wanted to give it a go as the Tein paint is notorious for flaking anyway ...
Next to my adjustable Leda coilovers - which are for sale if anyone might be interested ? ...
Test fitted to the rear of the ST165 ...
Reconditioning
Rustoleum Meadow Green is a good match for the Tein green ...
I laquered the topcoat and also the springs ...
Current cars
ST165 (project)
Previous GT4's
ST165 (sold)
Website
:infinity:
Users browsing this forum: No registered users and 120 guests
