It is currently Thu Oct 09, 2025 12:31 pm
 Post subject: Alternative fuel system
PostPosted: Wed Aug 13, 2014 9:47 pm
I am mulling over what I am going to do with the fuel system. I was going to keep the standard system...I may yet, but I was doubting wether it would be able to cope with the fuel demands of a 2.2.?
I was thinking about having a swirl pot made to fit in the rear inner wing, where the original aerial used to go. Then with an inline pump, running the fuel line inside the sill to the engine bay, this would be fed by the standard fuel tank and a walbro 255 pump.....or would the walbro be up to the job on its own?
PostPosted: Thu Aug 14, 2014 6:17 pm
Decided to stick with an in tank fuel pump only. This one should do the trick.
http://www.part-box.com/products.php?br ... atschwerks
PostPosted: Thu Aug 14, 2014 10:16 pm
In 300 form I take it?
I'd fire a quick question just to check flow rate @ say 60psi just to make sure but the spec looks good
PostPosted: Thu Aug 14, 2014 10:47 pm
Yes I would go for the 300
60psi @ 13.5v = 225l/s
100psi @ 13.5v = 185l/s
PostPosted: Fri Aug 15, 2014 9:31 pm
Per hour I think? ;)
I've read about the JZA80 Supra TT pump as OEM upgrade as well, but don't know how they compare to this one. New parts ftw though, specially when it comes to moving parts.
Users browsing this forum: Google Adsense [Bot] and 32 guests
