It is currently Tue Apr 23, 2024 10:09 pm
 Post subject: Bushing
PostPosted: Tue Nov 10, 2015 9:32 pm
Can you change the front control arm bushing a lot of play in it
 Post subject: Re: Bushing
PostPosted: Tue Nov 10, 2015 10:38 pm
The bushes are not replaceable by DIY. The best option is to purchase new arms. TCB are a good source for these.
PostPosted: Tue Nov 10, 2015 10:45 pm
cheers I'll have go down that route then expensive lovely
PostPosted: Tue Nov 10, 2015 10:53 pm
If you mean the banana shaped arm that goes back to the floorpan (effectively a tie bar to stop front/back movement) then the rear joint has a strange joint which is renowned for failure, and is simple & cheap to sort the problem. A search for crush tube should reveal all the discussions.
PostPosted: Wed Nov 11, 2015 12:11 am
It's the arm with the wee stud in the middle of it
