It is currently Fri Oct 10, 2025 4:37 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sat Mar 04, 2006 5:22 am
After some thought, this is the plan I'm going with. Currently trying to find an NZ supplier of centrifugal fans like this..
otherwise I'll get one from the US. Will flow soemthing like 200cfm which should easily be enough. Will mount it either low down in the engine bay or with a pick up that is low down and then run a 'hose' to a 'diffuser' which will aim the airflow between the WAI core and the cam cover. I'll also look at an additional heat shield above the cam cover - stainless or ally - and blow the air between that and the WAI unit. I anticipate having it running full time and rigging up some form of timer so it can run after the ignition is off - say for 10 minutes.
It'll almost be like the set-up the old MG Montego and Maestro turbos used. They had a similar set-up to blow cold air over the SU carb when the ignition was switched off to prevent the fuel in the carb evapourating (the carb was directly over the exhaust manifold!).
Gary
 Post subject: DATAJON
PostPosted: Sun Mar 05, 2006 8:47 pm
if the my o my was aimed at me then??????????
havent got a cold air box just a open hks spf was on it when it came from japan, i removed the resonator box(because couldnt see the point of it being there without the factory setup!)
i merely pointed out that temp. tests that id done did not have the same results as gt4wrc's
 Post subject: shroud round rad
PostPosted: Sun Mar 05, 2006 8:54 pm
the new impreza rally car is good example of that
