It is currently Mon Oct 06, 2025 5:35 pm
Post new topic Reply to topic  [ 168 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 12  Next
PostPosted: Sun Nov 25, 2012 6:54 pm
aluminium
GT Four Adovansu
PostPosted: Sun Nov 25, 2012 7:07 pm
I can't remember if they salt the roads in NZ in the winter but you might want to keep them well oiled/greased on the outside if you ever take it out in the winter. :)
PostPosted: Sun Nov 25, 2012 7:31 pm
They don't salt the roads in NZ thank goodness. My car, while 20+ years old has minimal rust on it. Even from being in Japan, the shell is corrosion free bar some slight rust spots.
Will see whether cheap fittings will do the job vs high priced earl's or similar fittings. Same mentality with push lock over crimped braid.
Hopefully there are no issues with either path being taken as it is all low pressure hose.
GT Four Adovansu
PostPosted: Sun Nov 25, 2012 9:11 pm
I think they'll be fine, especially if no salt and you keep the car garaged :)
PostPosted: Mon Nov 26, 2012 12:20 pm
20 Oct 2012: As I ripped out the heater and AC of the car, the original plan was to find a cheap alternative eg hairdryer fan + element. After reading reports over the years of their ineffectiveness and Jonno trying out a bilge fan to reasonable effect, I ponied up and bought a vintage air compact gen2 heater and demister from Summit racing.
One of the first things I did was test out the unit, and it pumps out a decent amount of air. But the unit is commonly made for american hot rods, which this car isn't. Doesn't have a flat firewall like a hot rod, has shifter cables routed on top of the transmission tunnel. This meant I had to think of a way to mount the unit and I had to match it to the factor demister vent.
Initially I was debating about using in the american configuration with the flexible hoses to the factory vent. But the actuated vent at the bottom of the unit vented onto the transmission tunnel and shifter cables.
There was also the issue of the inlet vent on the RHS of the car in the installs on the web. The factory vent from the scuttle panel is located on the LHS of the car as it is right hand drive. If I had mounted the unit as per american installs, then the air inlet would interfere with the steering rack boot.
So I took apart the unit to see if I could flip the inlet/fan around. This didn't work as the fan outlet to the heater core was offset.
In the end I turned the unit upside down, swapped two wires which control the flap actuator on the unit control panel and voila - auto flap for demister mated to the factory vent using a metal shroud. I'll make up some mounts to vent the footwells.
All in all, this has taken a long time to sort out - around a month to figure out all out, make unit mounts, orientate the heater hoses incl. time spent at the Hutt City Auto Parts digging around in their heater hose collection to find the most suitably orientated hoses, getting brass bulkhead fittings etc. in order to get good heat into the car.
The heater, bracing and shroud has taken a lot of time with me crawling in and out of the car, mounting the unit over and over again, trying to match the shroud to the factory demister vent. Overall, I'm happy with the result and just have to get a couple of items to complete the setup. Enjoy the quick snapshot of my pain figuring this all out.
Compact heater disassembled.
21 Oct 2012: Bent up 2x aluminium bars, drilled some holes in the scuttle panel wall (vertical mount to reduce water leakage through holes). Note tab to right of RHS mounting brace. Initially I didn't want to cut it off. Braces mount to factory points and the bolts used up top are stainless to reduce corrosion.
22 Oct 2012: Mounted to unit, added foam to reduce vibration.
30 Oct 2012: Made funny shaped cardboard template to match heater to factory demister vent.
Testing it out in the car. But after some thinking, this cardboard shape was too convoluted. Making the shroud in metal would be a complete pain!
1x angle grinder and cutting disc + executive decision = no tab!
To now match the heater unit to the vent, I had to move the unit around 40mm to the RHS of the car. That meant my braces were not in the right place. To match, I welded in some aluminium cross braces.
First time I welded aluminium. Beads came out okay. Still learning, but not bad IMHO :)
06 Nov 2012: Cutting up the shroud out of 0.8mm mild steel. Unit will be painted and covered in heat resistant material from DEI. Interesting note, when cutting thin metal with jigsaw, use small teeth blades. I think I was told 2-3 teeth per thickness (or something along those lines). Stops the jigsaw from catching. Also, when cutting aluminium, go at a slower speed. I killed a blade by clogging up the teeth with aluminium by going to fast.
Starting folding the metal up.
09 Nov 2012: Starting to come together
10 Nov 2012: As you can see, I bent the metal on wooden members as I had seen this technique on the web. Added some new knowledge to my brain on how to do this technique :)
Made a lip on the shroud to match up to demister vent.
Slightly better angle. I got a good tack between the funny angles to tie it all together.
Anyway - unit is mostly welded up. PITA to weld up such thin metal, but I got used to it.. until I ran out of argon *sigh. Still work to do, but I'll post up the rest of the shroud pics when I have finished.
23 Nov 2012: On a more interesting note, I ordered a Bullseye housing for my Holset HX35. I had it delivered to my cousin in Cleveland who sent out to NZ for me as the freight costs to New Zealand were exorbitant!
I finally got around to seeing if the housing fit the Holset and I mounted the MaxFab steam pipe manifold to the HX35. And to my great relief, the HX35 fits up very very nicely!
There is also clearance around the turbo inlet area. I was worried that there would be interference with the gearbox and clutch release mechanism. But no major issues. I will most likely bend up a new hydraulic hardline from copper nickel to ensure there is no interference from the cold air inlet pipe.
So pretty!
Manifold needs to be cleaned up. I still have to fab up an adaptor to mount my GFB wastegate to the manifold. Shouldn't be too much of an issue though. Still waiting for a small bottle of argon to arrive *sigh
Originially when I tried my friends wastegated HX40 housing, there was barely 7mm between the rear of the housing and the oil cooler. Now there is bags of room - huzzah!
24 Nov 2012: Back to the bloody heater, and some wiring fun.
I had previously welded up some holes in the firewall to smooth out the look. TBH, I should have planned this out more thoroughly at the start, but no one seems to have tidied up the looms in ST185s and documented what they had done. So my intention of using a small factory hole near the bottom of the firewall was curtailed when I routed the fuel and brake hardlines. The Deutsch plugs I had bought were also rather large.
So I decided to go through a hole I had welded up further up the firewall. This would also help when it comes time to drop the engine as the plug adaptor is in easy reach.
As I'm a bit lazy, I covered the steering rack and lines with some speaker carpet and went to work on the firewall. Shame my holesaw bit was blunt. $30 later and a new holesaw and I ripped through the welded in metal in a couple of minutes :)
Here is an interesting modification journey factoid. The metal that was welded in, bent when the holesaw went through the hole. It broke off the welds (arc welded in - not best idea). I had smoothed out the previous work with automotive bog. Now the bog is not attached to anything. I'm going to have to cut out the bog and replace with proper metal as the plug adapator has to sit flat on the metal. Oh well, new plate will be tigged in when I prep the bay for paint.
Because I am pedantic, I made a little paper catch for all the crap coming through into the cabin. Such small things just make life a little simplier e.g. I don't have to clean metal particles from the interior carpet.
And I drilled the firewall for the heater bulkhead fittings once I had orientated the interior heater hoses into the right place. It all takes time, but the end result will be fantastic once done. Note, Putting random holes into the firewall and then 'making it work' was not on the cards for me. Especially since I am trying to 'do it once, do it right' on this build.
Thats all for now. You are all mostly up to date with my progress :)
Dave
GT Four Adovansu
PostPosted: Mon Nov 26, 2012 1:07 pm
Never seen anyone go down that heat route before. Looks like it will work out well
PostPosted: Tue Nov 27, 2012 6:48 am
I found about the vintage air units from build-threads.com. There is a baja 1000 WRX being built and the owner built one into his car.
Page 10 of actual thread, link through here:
http://www.build-threads.com/build-thre ... ubaru-wrx/
I had a think about it and was considering the little electric radiant heaters for hotrods as I was going to recirculate the water on the pipes off the block with a heater hose U piece off a hilux.
Then I considered this:
1. The Hotrod heaters output 300W on a 30A fuse.
2. A typical car heater will output 15,000 to 30,000 BTU's
When you think about it in terms of energy used to heat the cabin, a heater core using recirculated water is very efficient. And the Celica engine bays are busy anyway, so trying to clean up two hose lines is mostly a lost cause. Original intention was to clean up engine bay and minimise hoses and the like, but the more I looked at the engine bay, the harder it was to tidy up.
And I'm 35 now and when I started the car 5 years ago I had all these grand show vehicle intentions. Those ideas have mostly been thrown out and I've gotten practical.
Just about to weld up the rest of the shroud as I've got my hands on another cylinder of argon and I bought a brass right angle to complete the interior heater hose setup :)
Job nearly done. I will post pics and video of what I have done
GT Four Adovansu
PostPosted: Tue Nov 27, 2012 10:53 pm
Cool to see we think along the same lines, lol. I'm going to use a kit car heater in my car so it's interesting to see your installation in detail. I have been looking into a single circular connector for my loom as well. I really want to go for a crimp type instead of solder type, shame about the hugely expensive tools (DMC crimper) needed for it. Do you have more info on your connector/tools? Love your attention for detail.
PostPosted: Wed Nov 28, 2012 6:25 am
Hey Rene,
The deutsch connector has crimp terminals. I won't be buying a special tool for crimping after discussing with my aircraft engineer friend. Will patiently fold the crimp tabs over and may use a ratchet crimper to compress the crimp.
If you want me to get more detailed, am happy to do so, but I have a full couple of weeks so it may take a little time to get the info posted up.
GT Four Adovansu
PostPosted: Wed Nov 28, 2012 10:23 pm
I'll keep following this topic and probably ask more when I'm actually at that point in my build. :)
PostPosted: Thu Jan 17, 2013 12:06 pm
This was my day today:
- pillaged parts in the rain at pickapart, subaru washer dual pump washer bottle for bottle relocation in boot and other bits and bobs
- got rather wet
- looked at IC piping again. Trying to 'adapt' a caldina gtt IC piping kit into a ST185 with ST205 engine and ST215 manifold. One side fits, other side doesn't. Means modification of the pass side IC route as caldina air filter hole on side panel is larger and front half of car profile is taller allowing for bigger hole on side
- cursed at my car repeatedly
- bought more parts / returned parts for manifold fittings, vacuum, hose routing
- Big thank you's to guys at Twiggs for so much patience. Cursed at st215 inlet manifold for having less vacuum outlets than st205 inlet manifold
- went into TSS red baron to shorten throttle cable due to st215 manifold and a st18x specific TB cable mount (*bleep* toyota.. no coronas, corollas or anything has the same bloody mount), didn't get very far as they didn't have the cable end
- cursed at my car repeatedly. Maybe Motomart of bike shop has something.
- Went to Hutt City Auto Parts and changed oil filter for my Derale thermo oil plate as filter too long and would get crushed if I went over speed hump due to only 2 filters which would seal the machined opening which is so close to edge to the plate - dropped 40mm off end
- smiled slightly and breathed sigh of relief at speed humps
- talked/though PS lines, death of standard rubber and looked at options to mount AN fitting PS cooler to cheaper PS hose which is available at parts store which isn't teflon lined or braided. Figured out I could use cheaper PS lines on push lock fittings and chuck a clamp on to fit cooler into car. BUT changes fittings list again and makes me rethink reservoir and routing, but is a hell lot cheaper and means no braided cutting up my engine bay
- smiled and cursed inwardly at no AN to NPT barb fittings. More cursing at stupid PS setup, but I refuse to have the ugly factory PS setup in my bay and I'm stubborn enough to make the aftermarket cooler fit.
- got told by seller that MR2 idle pulley I got for $15 is damaged
- looked downward to shoes and cursed more as I'll have to find another one
- planning tomorrows car work and its an alloy tigging day with ECU, fusebox mounting and maybe IC piping.
- slowly losing the will to live due to the bloody cufking car
*looks at car, thinks so close, yet still so far away. Still need to wire the car and build widebody fenders. Cufk that is going to take a bit of work..
GT Four Adovansu
PostPosted: Thu Jan 17, 2013 7:57 pm
Sounds like a fun day, NOT! The devil is in the detail as we are finding with the final assembly of my project.
PostPosted: Thu Jan 17, 2013 9:12 pm
Actually that has been reasonably productive considering the amount of time I've spent on the car over the last 3 weeks.
12-16 odd hours a day, 6-7 days a week just constantly working on the car and pushing to make decisions and figure out how this thing will get back on the road after 5 years.
More parts ordering today, more work today and I'm back at work on 28th so I have to finish up some major areas of the car before returning to work and get inundated with BS again.
GT Four Adovansu
PostPosted: Thu Jul 18, 2013 12:33 pm
Many moons have passed since I updated the project thread. I have been working on the car during this time though, so don't fear that another project has died.
Just to make it interesting... "nom nom nom!"
GT Four Adovansu
PostPosted: Thu Jul 18, 2013 8:29 pm
Lol :)
Nice to hear the project is still going :)
