It is currently Mon Oct 06, 2025 5:16 am
Post new topic Reply to topic  [ 82 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: pistons
PostPosted: Thu Dec 12, 2013 11:54 am
i'am using the CP too for the same reason and one further, it was easily possible to custom built them to 86,25mm bore and 9:1, the price was the same iirc i just had to wait a few weeks
the second reason was that i want rods and pistons from the same manufacturer -> CP / Carillo
so shiny when they are new :lol:
viewtopic.php?f=1&t=2908&start=285
PostPosted: Mon Jan 06, 2014 10:51 pm
I use Ross pistons. Any opinions on these? I notice a bit slap on cold start but can't comment on anything else as I only use it up to to 1.2 bar about 0.1% of the time..
St205 WRC - Running sweet.
PostPosted: Tue Jan 07, 2014 1:47 am
Ross in my opinion is very old technology in terms of pistons. Last time i checked there clearances were around 0.0060" which accounts for them being noisy.
Tim
TB Developments
PostPosted: Tue Jan 07, 2014 12:04 pm
I'm only running 0.0040" clearance, which was what nibbles and I decided on as i'm only running 1.2 bar and everything else stock. A torque plate was used..
(at least that's what I remember, nibbles may want to confirm)
http://www.supraforums.com/forum/showth ... -clearance
PostPosted: Tue Jan 07, 2014 2:40 pm
well alot of the specified clearances are set because of the material spec used and the skirt design, thickness, shape etc etc.
You can change the clearance of them a little but don't think just because it might be made of the same material as say a JE you can then run the same clearance values.
Tim
TB Developments
PostPosted: Tue Jan 07, 2014 6:04 pm
True, we did quite a bit of research and found many application of Ross pistons with 0.0040 clearance. Ross even changed the 0.0060 clearance spec down to 0.0050 which might suggest they were initially a bit conservative. Going from 0.0050 spec clearance down to 0.0040 seems to work. Time will tell.
PostPosted: Tue Jan 07, 2014 7:50 pm
maybe they did a bit of a redesign to come more inlines of the new range of pistons being produced by other companies. Even 0.0040" is conservative for some pistons on the market.
i once did a couple sets of custom CP for testing that were 0.0012"
Tim
TB Developments
