It is currently Fri Oct 10, 2025 5:36 pm
 Post subject: springs
PostPosted: Fri Jul 08, 2011 7:51 pm
st205 gt4 springs compared to a regular celica gt or gts, i have trd struts on the rear of my gt4 and want to lower it. My question is are they the same springs as the non turbo gt etc? i only need rear and dont want to pay $300 for gt4 springs when i can get regular celica springs for $150, anyone know if the springs/struts are the same?
thanks
PostPosted: Fri Jul 08, 2011 8:38 pm
Hi Simon,
you can easily compare part numbers at this homepage
http://www.toyodiy.com/parts/
iirc you can buy TRD springs by paire, which means you should can get just the rear ones, i would ask fensport as a friend of mine bought a set a month ago
PostPosted: Fri Jul 08, 2011 8:55 pm
I don't know the difference in spring rates between a GT4 and GT but logic would say that you would need a higher rate spring on the GT4 as the rear diff, driveshafts and prop shaft will all combine to make the rear heavier than the Celica GT. It may not be a huge difference but you may find if you fit GT springs that they sag over time.
PostPosted: Fri Jul 08, 2011 9:47 pm
perfect i will contact fensport hopefully they will ship to canada, thanks for the help again guys :)
PostPosted: Mon Jul 11, 2011 4:08 pm
Different length struts & springs on the n/a ST20x compared to the GT4 - completely incompatible.
Caldina Blog
PostPosted: Fri Jul 15, 2011 10:07 pm
ya i just checked on a buddys car and its a no go, thx
Users browsing this forum: No registered users and 5 guests
