It is currently Mon Oct 06, 2025 11:17 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Oct 04, 2011 11:08 am
Will a Garrett 3071 and tial wastegate fit with a c-one tubular manifold with the standard fans and radiator?
This is something I'd like to do when the new turbo / injectors get fitted :)
Thanks 8)
351PS, 454Nm ST205 WRC @ 1.2bar | Stock engine
PostPosted: Tue Oct 04, 2011 6:46 pm
Hi Daz the C-ONE is a direct replacement for the standard 205 cast mani ie sits in the same place well as far as i know it does?
PostPosted: Tue Oct 04, 2011 6:54 pm
You'll need replacement fans...
PostPosted: Wed Oct 05, 2011 7:29 am
definately, my brothers 3071 is very close to the slimline fans as it is
PostPosted: Wed Oct 05, 2011 8:43 am
Cheers guys. I'm using a standard rad so what are recommended? Maybe 12" spal push fans? I've removed the aircon.
Are there any recommended Spal(like) fans that don't cost £80 each?
Thanks guys
PostPosted: Wed Oct 05, 2011 11:42 am
You get what you pay for in my experience. Buy cheap, buy again when your engine starts overheating in traffic.
PostPosted: Wed Oct 05, 2011 2:12 pm
Thanks guys
I would go for, indeed went for, 2 x 12" SPAL puller fans.
(you need to consider the CFM rating on the fans)
That was with a Koyo rad.
Pusher fans will restrict (to a certain extent) the natural air flow through the radiator = not good.
The following is from the Discounts thread/section:
If you are in need of radiator fans - they don't come much better than Spal fans.
So, I am very happy to confirm and announce that GT4 Drivers Club members will get a 'best price' gaurantee on any Spal fans by contacting Alan at Fereday Cars http://www.feredaycars.co.uk/.
PostPosted: Thu Oct 06, 2011 9:41 am
We've just fitted a TB developments 3071 externally gated kit on my friends Celica.
We've fitted a Koyo rad to it which is a fair bit thicker than the oe one. We couldn't refit the stock main fan with the larger rad but we have rewired the air con fan as the main one and this is re-fitted. The rad holds about 2 litres or more water than the stock one. We've plumbed in a water temp gauge so we'll see how this copes before ordering any alternative fans.
It's a really tight fit and we had to completely re-route the front mount intercooler kit.
Nito
Admin Edit: Image changed to link
PostPosted: Thu Oct 06, 2011 1:18 pm
Thanks Admin,
I was going to change it to URL. Is there any reason I can't get the [img] tags to work? Is that down to post count or something, I can see it works for some people? BB code is set to on at my end.
Thanks
Nito
PostPosted: Thu Oct 06, 2011 1:27 pm
NITO wrote:
Thanks Admin,
Thanks
Nito
You need to use a photo hosting service like Photobucket to be able to then insert images as an <IMG>.
PostPosted: Thu Oct 06, 2011 2:38 pm
Apologies for the off topic, pic re hosted elsewhere.
Nito
PostPosted: Thu Nov 03, 2011 2:52 pm
Cheers guys. Sorted now!
PostPosted: Thu Nov 03, 2011 3:36 pm
pictures or it didn't happen! :D
PostPosted: Fri Nov 04, 2011 12:07 pm
No tubular manifold :(
PostPosted: Fri Nov 04, 2011 4:39 pm
what boost were you running mate? and wheel bhp or fly?
