It is currently Mon Oct 06, 2025 10:32 am
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: Archers forged rebuild
PostPosted: Sat Mar 30, 2013 9:02 pm
Another forged build for you all to follow, this ones for archer
Some of the probs found when stripping the engine from the car
Locking nut covers missing on fig 8 nuts
Split vsv hose
Clips not fitted correctly
Snapped power steering idle up steel pipework
Power steering pump main pivot bolt missing
Head removed
Rocker cover underside
Worn out clutch
Martin
We now have a new website
PostPosted: Sat Mar 30, 2013 9:08 pm
Crank journals condition
The crank timing pulley was seized on the crank and wouldnt come off so had to delicately slice the pully and then split it to get it off
Martin
PostPosted: Sat Mar 30, 2013 9:14 pm
Very poor bore condition
The rusty section across the bore on the pic above is actually a crack :(
The failed no.4 piston
Martin
PostPosted: Sat Mar 30, 2013 10:06 pm
did the car come in because of engine failure or an upgrade?
looks like a much needed engine build
Toyota Celica GT4 ST205
Toyota Celica GT4 ST185
PostPosted: Sat Mar 30, 2013 10:20 pm
Ye it is a lad from scotland the engine failed on him 2 weeks after buying the car unfortunately
Martin
PostPosted: Sat Mar 30, 2013 11:09 pm
Looks like another ST205 which has been run on the smell of an oily rag :( I guess a replacement block is required? Hopefully crank can be saved. If not give me a shout as I have loads of parts.
PostPosted: Sat Mar 30, 2013 11:33 pm
was there much oil in the sump when you drained it martin? Im gutted for the guy, hope he got it cheap knowing it was going to need work. Id def be contacting the seller just to vent my frustration at a poorly maintained motor
PostPosted: Sun Mar 31, 2013 9:28 am
gutted for the person, shocking and to be honest, it appears like Don says that its yet another person buying a st205 because they are cheap, then realising at the first service bill they cant afford to fix it so do it on the cheap or even better.... just dont at all.
PostPosted: Sun Mar 31, 2013 9:53 pm
Matts cool he is under no illusions and has cut no corners, he has fully listened to my advise and gone with suggestions made.
The engines actually rebuilt and back in the car, if I get other work done in time it should be another 4 saved on tuesday when I turn the key plenty more pics to come as well as more builds to show, got another 4 builds after this one including another stroker with offset ground crank and a linered build which will be interesting to share
Martin
PostPosted: Sun Mar 31, 2013 9:56 pm
Hiya don
I had to replace the crank but thats all sorted now cheers, mike was showing me your build this weekend whilst he was over looks seriously impressive can`t wait to see it in the flesh :)
Martin
PostPosted: Sun Mar 31, 2013 9:58 pm
is the crank between no.3 and 4?
PostPosted: Sun Mar 31, 2013 10:32 pm
Hiya
The pics are of all the journals they were all marked up
Martin
PostPosted: Mon Apr 01, 2013 12:44 pm
sorry, used the wrong word, i mean crack
i would guess it is between chamber no2 and 3 thats a point of where a water channel is running between both
PostPosted: Mon Apr 08, 2013 11:29 pm
Hiya
To be perfectly honest I can`t remember now will have a look in the unit see if I still have the block
Martin
PostPosted: Thu Jun 13, 2013 11:09 pm
So onto the big clean up and sump modifications for the arp studs
Checking the clearance of the studs
Refurbed head
Pistons and rings in order for assembly
Piston ring end gap grinding
Tools for checking ring end gap grinding, note the ring setting tool ive had made
Ring gaps ground
Pistons and rings ground ready for assembly
All new plugs and gallery bungs installed
Martin
