It is currently Tue Oct 07, 2025 12:28 am
PostPosted: Mon Nov 18, 2013 4:35 pm
Hello
Is it possible to mount a blitz ecu of st185 Alltrack in ST185 cs?
If the watercooler ecu is disconnected , continues to operate the pump?
Causes this code? Breakdown and check light on?
Greetings
PostPosted: Tue Nov 19, 2013 11:11 pm
It won't be mapped to measure the air flow through the larger AFM that the CS/rc have. So no, don't use it unless you down grade the AFM to match the normal sized one in the st185
Darryl
Darryl
PostPosted: Sun Nov 24, 2013 12:06 pm
It will not even start. A mate of me bought a Blitz Access for his CS and it didn't start with it. Than he found out that it was a ECU for a normal ST185. The AFM of the CS/RC is not only have a bigger diameter, it also have a different connector with one pin more.
PostPosted: Sun Nov 24, 2013 1:14 pm
Car Model: ST165
yes it is possible, but gains are poor. in my opinion = poor value for money.
For a short while, I used a '91 - '93 SW20 SARD Analysis ecu on my ST185 RC and it was plug and play....
But i felt the car drove better on the stock RC ecu.
Gary ST165 wrote:
SARD Analyse JDM 3sgte ECU '91-'93 spec
Manufactured by SARD CO. LTD serial number 0893
Toyota Denso part number 89661-17380
Image Image
It is essentially a plug and play 3sgte ECU for JDM ST185 manufactured after August '91 & rev2 SW20 MR2 Turbo.
I don't remember if the above will work on a UK or Euro spec Carlos Sainz.
The charge cooler pump operation is controlled by a separate ecu and triggered by teh throttle position sensor as i recall. Hence is unaffected by using a different ecu, and will not produce error codes.
ST165 turbo 4WD
PostPosted: Tue Nov 26, 2013 3:00 pm
Image Image
could buy a sard, and take it to chiptuner and passed to the microprocessor to st185cs Eurospec ecu, and that maps for my car.
PostPosted: Tue Nov 26, 2013 3:03 pm
Image Image
Or buy 89661-17380 sard tuned ecu, if it is plug and play for my st185cs.In the photo its 0892,you say 0893
How many extra hp at 1,1bar on ct26?
thanks
PostPosted: Tue Nov 26, 2013 4:09 pm
What fuel do you use?
ST185 CS #1845
PostPosted: Wed Nov 27, 2013 2:42 am
98oct
PostPosted: Wed Nov 27, 2013 7:16 pm
I have a Mines ECU in my CS. Usually I use 102 octane fuel. Makes a uge different to 98 octane.
PostPosted: Wed Nov 27, 2013 10:21 pm
In Spain only 98 oct max. :cry:
PostPosted: Wed Nov 27, 2013 11:28 pm
I life in Germany. Most Shell stations sell 100 octane here and the bigger Aral stations have 102 octane fuel (both for an insane price) .
