It is currently Thu Oct 09, 2025 8:05 pm
PostPosted: Sat Mar 11, 2006 4:35 pm
Looking at a d/p for sale.
It's come off a 205 so I'm sure it will fit fine on my CS.
Where can I get all the gaskets and bolts (or a complete fitting kit) for the d/p and does it need to be model specific? ie. aussie fitting kit for a st185 or are the fitting kits universal?
Cheers guys.
Steve
PostPosted: Sat Mar 11, 2006 6:06 pm
Theres one bracket on the lower bend of the dp which you could make yourself. Its a nearly triangle. It just ankors to the block. Then there is exhaust paste and 3 bolts & nuts.... voila :) You'll probably find the mods have some company they can recommend for parts.
I need to take some piccys for Kris, so I'll shoot the zorst/dp at the same time :)
Cheers,
Tone
Now offering:
PostPosted: Sat Mar 11, 2006 6:12 pm
Sadly the bloke selling it doesn't know what make it is nor has any fittings for it. It's wrapped in heatwrap too.
Think I'd rather have a new one myself.....especially with the much needed support bracket to strengthen the pipe.
 Post subject: who selling it steve?
PostPosted: Sat Mar 11, 2006 7:18 pm
how much etc.
PostPosted: Sat Mar 11, 2006 9:16 pm
Right i'm upto speed on this one at the moment.
the is no difference that i am aware of between the 185 and 205 decat pipe.
The gaskets are avalible from Fennies or toyota however Fennies charge £20.97 for the Turbo gasket while the lower one is maybe a fiver.
They are MR T Gaskets so probably cheaper from dealer.
I'll Look i might have a spare.
There is also a reducer ring to drop down from the 3" DP to 2.5" System.
The bracket you can make as already stated i can make a template of the one i have and mail it to you if that helps.
I got a cheap decat it's not an Aussie but looks good and will do the job nicely and the fit is perfect. It has all the gaskets and bolts to fit and has bungs for wideband and EGT.
It's only an XS Power one but to be fair for the price it is excellent there is only a scruffy bit of welding around the inside of the O2 sensor that needs cleaning up but not really a big issue.
Mine cost me £80 all in including delivery from america via fedex.
1990 JDM ST185 Grey.
ST205 head gasket.
ARP head bolts.
ST205 Koyo Rad. (almost)
Front mount intercooler.
Colder plugs.
3" decat pipe.
4 Branch manifold.
