It is currently Thu Oct 09, 2025 8:20 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
PostPosted: Thu Nov 27, 2014 7:10 pm
Been turning some Race Spec diff subframe bushes
BRD Page
http://www.brooks-brd.co.uk/
PostPosted: Sun Nov 30, 2014 1:52 pm
few more diff mount off out in the post Image
and 2 mounts to Australia
BRD Page
PostPosted: Sun Nov 30, 2014 5:03 pm
ST185 or ST205?
PostPosted: Sun Nov 30, 2014 5:35 pm
fits all the 165-185 and 205 all use the same diff mount and diff subframe bushes
BRD Page
PostPosted: Sun Nov 30, 2014 5:50 pm
I asked Martin Kingston on Friday about this when he was down to pick up the trailer and he has confirmed the 185 and 205 diff mounts are different internal diameter. He is going to send me the measurements. I'll post them up on the forum when I get them. He says there are other differences in the diff mounts too.
PostPosted: Sun Nov 30, 2014 6:11 pm
i have a 185 diff subframe and 205 diff subframe and both measure the same size? all so iv had diff mount form 165-185 and 205 and all are the same even Toyota list them as the same
BRD Page
PostPosted: Mon Dec 01, 2014 12:13 am
For everyone's information Lou and I are still working to confirm the dimensions of the 185 and 205 diff carrier bushes as we have conflicting dimensions. More info to follow :)
PostPosted: Wed Dec 03, 2014 12:11 am
Aaahh balls sorry forgot to measure I will do it tomoz
The 185 and 205 diff carriers are interchangeable but different the diff carrier bushes leave a gap on the 185 underneath, the 205 sits flush, I will try dig pics up to show ya what I mean so unless toyota have superseded the old part numbers to the rev 3 then the should be different, this is exactly why I fitted the 205 variation to my cs, I will measure for you tomorrow to confirm one way or another make sure am not imagining with the diameter of the bush :-)
Martin
We now have a new website
PostPosted: Wed Dec 03, 2014 12:22 am
cheers bud that will help, as I have a 185 diff carrier and a 205 carrier and they both take the same bushes
BRD Page
PostPosted: Wed Dec 03, 2014 1:33 am
I will text you tomorrow lewis, if I dont then send me a text to remind me please lol
Martin
PostPosted: Wed Dec 03, 2014 11:18 am
To illustrate the difference between the ST205 and ST185 differential carriers (N.B. NOT the rear subframe!) I've posted my pics below:
ST205 Diff Carrier with OEM Bush
Diff Carrier
ST205 on the left and ST185 on the right. you can see the rusty surface where we removed the old bush metal jacket after the diff carrier had been powder-coated. I originally thought the metal jacket was part of the diff carrier :oops:
BRD Bush in ST205 Diff Carrier
The bush was quite loose with at least a couple of mm clearance
BRD Bush in ST185 Diff Carrier
The bush could be pushed in by hand. No press required.
PostPosted: Wed Dec 03, 2014 2:59 pm
thanks for the photos will help. getting kits for both sorted .interesting to see that there seems to be a few mm difference on the 205 frame to the 185. but then the 205 frame i have seems to be same size bush as in the 185. ill pop photos up of what have when home tomorrow
BRD Page
PostPosted: Wed Dec 03, 2014 8:48 pm
ok so go some photos of the 185 and 205 diff subframe that I have
205 diff subframe on the right 185 on the left
205 frame
185 frame
205 bush in 185 frame
205 bush in the 205 frame
race bush in 185 frame needs a bit of a push to make it fit
same race bush in a 205 frame , still nice fit may be need to be about .5-1mm bigger
205 bush on the right 185 on the left
BRD Page
PostPosted: Thu Dec 04, 2014 12:25 am
Hiya lou
The 205 bushes need to be just shy of 51mm ;-)
Martin
PostPosted: Thu Dec 04, 2014 10:28 am
cheers bud. the last 205 set neededa tap in with a hammer so were a bit tighter. but ill be turning 1 at 50-51mm and see what its like to fit
BRD Page
