It is currently Wed Oct 08, 2025 12:20 pm
 Post subject: 3 inch exhaust
PostPosted: Tue May 19, 2015 7:56 pm
Hi!
I'm going to replace standard St205 exhaust system. I bought Blitz Nur Spec catback system and Japspeed downpipe. All of these is 3 inches. I'm just wondering is it a huge stupidity to leave as standard front pipe? I mean 3' downpipe, 2,25' front pipe and 3' catback.
What about boost creep?
 Post subject: Re: 3 inch exhaust
PostPosted: Tue May 19, 2015 9:17 pm
The name cat back suggests it should go all the way from the cat (downpipe) to the rear end.
PostPosted: Wed May 20, 2015 5:51 pm
No it isn't catback system, sorry for confusion. I meant that one http://www.blitz-uk.co.uk/ProductItem-109.aspx
So what are you thinking about leaving standard 2.25' inch front pipe?
PostPosted: Wed May 20, 2015 8:50 pm
The Blitz Nur Spec R system is actually 70mm which is 2.75". You will get the most benefit out of the 3" downpipe although ideally you would also have 3" front pipe/flexi section rather than the 2.25" pipe. One of the benefits of running that combination would be slightly more exhaust back pressure than a full 3" system and this would help reduce the chances of boost creep. I used to run a 3" downpipe and frontpipe mated to a Blitz system and it worked well.
