It is currently Wed Oct 08, 2025 8:52 am
PostPosted: Mon Jan 26, 2015 3:18 pm
hi im new on this site any one know what is the best knock sensor for the gt4 jdm 95 model oem or?
PostPosted: Mon Jan 26, 2015 4:35 pm
An OEM sensor would be my choice. :)
PostPosted: Mon Jan 26, 2015 5:17 pm
ok thanx because i got a 52 erro code i put a toyota n81 knock sensor on and no more 52 code then i put the old back on then again 52 code can i use the n81 toyota sensor the car start nice and idel nice to run good to but not the original toyota denso h99-03q28-03177 and im living in the philippines very hard to find the original one here but if the n81 can damage my car i vill get a new original one thanx
PostPosted: Mon Jan 26, 2015 7:08 pm
The standard knock sensor is highly tuned to the frequency emitted by knock on these engines. Using anything else will leave you with little knock protection
PostPosted: Mon May 11, 2015 1:55 pm
hi anyone know whats wrong with my breaks the left rear dont have any pressure and i cant c any leak anywhere check all the brake pipes and hoses its a gt4 jdm model 95 cheers all gt4 fans
PostPosted: Thu May 14, 2015 6:46 am
Your brakes issue should be on a new thread so it doesn't t get lost, but in the mean time, have you tried bleeding the (rear) breaks, this will at least give you an indication that things are working as they should ... Or not?
Could possibly be a stuck calliper?
Loosey
Loosey@gt4dc.co.uk
Storm Blue JDM ST205
Super White JDM ST205
PostPosted: Thu May 14, 2015 10:33 am
hi i tray the bleeding nothing coming out then i lose the hose and still nothing coming out even engine running and breaking and the break pedal is hard like normal any idea
PostPosted: Thu May 14, 2015 6:56 pm
Blocked or jammed bias valve possibly.
or faulty ABS pump if it's an ABS model.
PostPosted: Wed May 27, 2015 5:59 am
hi any one have a diaphragm over the break line system of the celica st205 gt4 jdm model year 95 because i don,t know what break pipe from the big alloy box going to the rear break cheers all gt4 fans
PostPosted: Thu May 28, 2015 8:34 pm
You should find the following useful:
https://www.dropbox.com/s/2vk8p6ycjynvb ... e.pdf?dl=0
https://www.dropbox.com/s/2y1udown5ioaa ... e.pdf?dl=0
https://www.dropbox.com/s/3n35dvydzb95c ... 3.pdf?dl=0
