It is currently Wed Oct 08, 2025 10:14 pm
PostPosted: Mon Mar 20, 2006 4:02 pm
I need to relocate this, any clues on what pipe work to use - also where have you located yours?
I presume the gearbox oil will need filling after this - where do i fill this up?
Rob
PostPosted: Mon Mar 20, 2006 4:39 pm
From memory the gearbox lines are 5/8 UNF, I'd use some stainless braided hose in at least 5/8 size with fittings.
http://www.thinkauto.com are good for this sort of stuff.
The gearbox is filled from a plub on the front of it, its probably best to do a complete change of the gear oil if your moving the cooler anyway. Remember that there are two drain plugs aswell. There's a decent picture somewhere on Kris and Loosey's website http://www.gtfours.co.uk
No idea on where you should put it - I guess it depends on the reason why it needs moving. On a side note - if you have a JDM car it might also be a good oppertunity to upgrade to the UK spec cooler or a similar size aftermarket item. :)
PostPosted: Mon Mar 20, 2006 5:23 pm
I need to relocate due to a FMIC being in the way, it's in a place where it really needs some attention - looks like it could drag along the floor
PostPosted: Mon Mar 20, 2006 7:21 pm
Rob,
Take a look Here for pics of where Kris relo'd his to post frontmount
It's a very tight fit but fit it does
Pipe wies I can't quite remember how it happened (it was about 10pm when we got it in place LOL).
As I recall we re-used the stock connections to the Rad for their 90 bend and the connection to the cooler. If I remember rightly we cut these after the 90, flared the end then used flexi to connect back to the original pipes.
Kris or Jon might have better pics of the final result
PostPosted: Mon Mar 20, 2006 7:53 pm
Robbie - if you turn around the stock hard gearbox lines then they have a near 90 degree bend to route them from the cooler back towards the gearbox.
Datajon came to the rescue with a flaring tool so that these could be connected onto the stock gearbox lines.
Note that the pipes shown below were cut and bent a little to get the required position...
The cooler is a bloody tight fit, and I would recommend a slightly thinner core to the next guy who does this to allow a little more room! :shock:
PostPosted: Mon Mar 20, 2006 8:44 pm
i don't think there is enough room on mine to do it, was mounting under the engine not satisfactory?
PostPosted: Mon Mar 20, 2006 9:01 pm
Looks a very tight squeeze in Kris' pic. If they are touching I'd be concerned that vibration would damage the core of the FMIC and/or the gearbox cooler/pipework. It all depends on how they are mounted relative to each other.
My thinking was to change the cooler to a standard low profile type of aftermarket motorsport cooler and remote mount it. Not sure exactly where though.
PostPosted: Mon Mar 20, 2006 9:47 pm
Don - the problem in reloacting the cooler is that you really want it in a direct path of some air. This limits you in where you are going to position the cooler.
The pic shows that the space is very tight, but there is a gap between the cooler and the FMIC.
Note that you will have to use solid pipework as there will not be enough room with flexi ones.
A final solution and mounting arrangement is coming...
PostPosted: Mon Mar 20, 2006 10:11 pm
i'll wait for the final version - i'll make it as secure as i can in the mean time
Cheers guys
