It is currently Tue Oct 07, 2025 1:04 am
 Post subject: Copper Head Gasket?
PostPosted: Sun Nov 01, 2009 11:57 pm
As i'm on a shoe string budget, i was wondering if i made a head gasket out of copper sheet would it be ok to use my st185?
I made a copper head gasket for my Yamaha 1000 some years ago and it worked fine!
Exup
PostPosted: Mon Nov 02, 2009 7:33 pm
A stock 205 gasket is about £30...
PostPosted: Mon Nov 02, 2009 8:48 pm
I thought a 205 head gasket was different to a St185 head gasket. The engine block i have is a 205 and the cylinder head i'm using is from my St185.
I have been told a uprated head gasket will cost a £120.
Exup
PostPosted: Mon Nov 02, 2009 10:22 pm
this may assist in identifying differences between the head gaskets.
ST205 & TTE are metal - St185 is standard paper type
PostPosted: Mon Nov 02, 2009 11:01 pm
I will have to use a St185 head gasket, but not a paper one, thats why i was considering making a copper one.
A St205 head gasket has different water ways to my St185 cylinder head.
Exup
PostPosted: Mon Nov 02, 2009 11:12 pm
How much are the TTE St185s gaskets from Florian nowadays? They can't be £120 are they?
PostPosted: Mon Nov 02, 2009 11:30 pm
Had a guy tell me a complete gasket set is £124 and then i did a Google search and found a company selling them for £72.36p. Unfortunately the gasket set has a paper gasket which i dont want.
I need a cometic head gasket, like the steel ones on a St205, but my cylinder head is a 185 Gt4 cylinder head + the head gaskets cost a fortune uprated!
Exup
PostPosted: Mon Nov 02, 2009 11:36 pm
try contacting....
florian dot bachus at toyota-f1 dot com
at TTE
They do 1.2mm and 1.4mm MHG. I am unsure of current prices but I seemed to remember they were circa £60-£70 (plus P&P and maybe import tax if you got caught so may not be that cheap :-( )
As you say some of the old cossies and R5 Turbos used copper head gaskets for high boost application. From discussions last week over a curry with some of teh guys they may have had "steel o-rings" built in??
Not sure TBH sorry.
PostPosted: Tue Nov 03, 2009 11:06 pm
Im running a standard 205 (1.2mm) HG in my 185 CS and have done now for 2 1/2 years with no problems what so ever. Dorris
Black CS 2771
PostPosted: Tue Nov 03, 2009 11:44 pm
Looks to me like the 205 one has larger slots for the waterways but is otherwise largely the same. I wouldn't have thought it would matter unless there's a problem with allowing too much water flow into the head too early causing unbalanced cooling.
Offer a 205 gasket up to both block & head and check that none of the areas common to both are blocked off more than they would be with a 185 gasket.
PostPosted: Wed Nov 04, 2009 12:12 am
I wonder if the difference in the holes is due to the ST185 having the extra water outlet on the back of the block.
PostPosted: Wed Nov 04, 2009 12:00 pm
Im thinking of buying a standard St205 head gasket and using it on my St185 head as a cometic 185 cost a fortune!
Has anyone modified a 205 head gasket and fitted it to a 185 cylinder head?
Exup
PostPosted: Wed Nov 04, 2009 7:53 pm
My advide would be NOT to buy a complete gasket set. A bit of a waste of money and you don't ever seem to use all the gaskets... and of the ones you do require, you won't know EXACTLY which one fits where as if just comes as a "pile" of seals and gaskets.
Whereas if you buy individually you know which gasket goes where and they are in protective bags as well :)
Has anyone modified a 205 head gasket and fitted it to a 185 cylinder head gasket?
Dorris has already mentioned he has done it, up there ^.
A 205 gasket fits to a 185 block and head, talk to Dorris.
My advice would be to save your money and buy a genuine gasket brand new from Toyota, (and some ARP Head Studs).
