It is currently Tue Oct 07, 2025 9:26 am
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
PostPosted: Sat Nov 07, 2009 7:43 pm
A question for who has TTE rods in his engine, and is using the car in track and not for 10-seconds "races":
where did you put your rpm limitter?
I'm asking because last Sunday I used for the first time the car in track after the latest mods, and at 7600 it's still pushing fecking hard...
Wolf
Wolf_Tm
TM 250 enduro 2 stroke
PostPosted: Sat Nov 07, 2009 11:30 pm
I've got TTE rods but decided not to fit them as my engine spec is now 500+bhp. I've used Carillo rods instead. The TTE rods were designed for rally use (~400bhp @ ~7000rpm) so I wouldn't be confident of using them in an engine built for circuit use where the rev limit and power output is higher.
PostPosted: Sun Nov 08, 2009 9:21 am
Mmm... I'm using them till 2007 and never had a problem even if my bhp is MUCH higher and I always used them to 7600 rpm.
AFAIK, and as far as I've seen when I installed them, the TTE seems to me to be the stock (100% SAME design) with, maybe, different material...
so would be very strange if the stock could reach 7500 rpm and the TTE no...
Moreover I know for sure they are using here these rods even in de-restrictored 3SGTE for ice-races (for example Yaris with 450 bhp).
BTW, it sounds correct that if approaching to 8000 rpm, it would be better to change to other stuff...
Wolf
Wolf_Tm
PostPosted: Sun Nov 08, 2009 11:45 pm
Yep, the rods look pretty much the same as the OEM ones. Like you say I think the material must be upgraded. The finish is still pretty rough so before using them I'd probably get them shot-peened, polished etc.
PostPosted: Mon Nov 09, 2009 9:55 am
more surface can transfer heat better :)
this is why i'am not a fan of painting the block and head
PostPosted: Mon Nov 09, 2009 10:27 am
Wolf_Tm
PostPosted: Mon Nov 09, 2009 11:33 am
a rough surface like the head-cover can transfer heat better against a polished as it has more surface
here a extreme example:
on top a rough surface, and on buttom a polished
PostPosted: Mon Nov 09, 2009 11:42 am
Sunny... believe me... I perfectly know relationship between surface and temp transfer...
I don't understand relationship with rods and limitter
Wolf_Tm
PostPosted: Mon Nov 09, 2009 12:14 pm
Hi Wolf,
ok 8)
PostPosted: Mon Nov 09, 2009 7:42 pm
Other meat for the BBQ:
Wolf:
Mr. XXX,
talking about the TTE connecting rods (Japanese ones) for ST205, I need to know their maximum safe rpm limit for track use.
Thank you, regards.
Mr. XXX:
Hello Sir
Maximum is 8500 RPM
With kind regards
Wolf_Tm
PostPosted: Tue Nov 10, 2009 12:05 pm
http://www.youtube.com/watch?v=njbj6xeYCoU
I definitely need to raise up a bit the limitter... :D
Wolf_Tm
PostPosted: Tue Nov 10, 2009 12:26 pm
Balancing and also piston selection will play a major role in RPM limit too
e.g AlBe (Aluminium Berillium or "Unobtainium" to the common person) pistons of 2 ring slipper racing spec would probably double the rev limit due to their ridiculously low mass
PostPosted: Tue Nov 10, 2009 1:56 pm
Yes, it absolutely has sense that an inertial mass reduction will decrease rods' stress.
I have modified wrc pistons in, so rpm limit must be higher than with stock pistons, even if i remember they were not so light as the as the cp i had in the past...
Wolf_Tm
PostPosted: Tue Nov 10, 2009 11:19 pm
Heavy rods and heavy pistons = same stress on con rods etc at lower rpm than lighter pistons and rods.
I have a formula to work out the stress placed on the con rod for fitting different weight pistons and rods.
This is in an excel spreadsheet, anyone interested then drop me a line with your email address and I'll send it over for all you geeks to look at/use :P
PostPosted: Wed Nov 11, 2009 10:10 am
Hi Kris,
interested :)
gasthof-hackl@gmuendnet.at
Alex
