It is currently Tue Oct 07, 2025 7:33 am
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
PostPosted: Wed May 18, 2011 10:10 am
Hiya
Does anyone have the part number for the pipe shown in picture
(or even what it is actually called may assist)
I went to Toyota with the picture and ordered what they said it was but looks to small ( i cannot get down to the garage to check against other one today due to couple o bad days )
As this pipe is on the back of the block i wanted to get it sorted asap as will have to re-order today to get before this Saturday when engine may possibly be put back in
I have tried to look through what documentation i have but am unable to find the part number, hence the calling on some assistance
Many thanks for reading
Chris
PostPosted: Wed May 18, 2011 10:43 am
derivation hose n5 ?
16282-88380 form 8910 to 9311
PostPosted: Wed May 18, 2011 11:22 am
IIRC it is a ST165 block and the car is an E reg so around 1987 (very early St165 JDM).
I suspect it is the same part as used on the St185
PostPosted: Wed May 18, 2011 11:42 am
Thanks for replies
The hose they sent is the 16282-88380 water by pass hose ( but i am sure that that is too small
JP......... Car is 88 on an F reg
The pipe is on the rear of the block.... and cant seem to see it on your diagram....am i just being stupid or over done my meds lol
Cheer Chris
PostPosted: Wed May 18, 2011 12:42 pm
Car Model: ST165
The water by-pass no.5 hose ought to be on here:
>>> http://www.megazip.ru/ru/auto/toyota/vi ... 217/366345 <<<
my EPC appears to show the same PNC 16282 & part number 16282-88380 hose, water by-pass, no. 5
ST165 turbo 4WD
ST185 GT-FOUR RC Carlos Sainz Limited Edition 825•5000
ST185 turbo 4WD Carlos Sainz Limited Edition 2541•5000
PostPosted: Wed May 18, 2011 12:45 pm
They could be the same item BUT it looks like you may have the wrong part :-( ....
PostPosted: Wed May 18, 2011 12:57 pm
Looks like they are the same then Gary.
Jingo - can you measure the internal bore both ends of the hose - I can check against my block & hoses for st185 in the garage for you.
PostPosted: Wed May 18, 2011 3:14 pm
Thats the pipe i have ie they sent but the pipe i want is on the other side of the block
cant get down to garage today so cant measure
It is on the manifold support stay side
coolant bypass hose is the opposite side of the block ie the front side by the oil filter ( which as i have it i may as well replace that one as well
Chris
PostPosted: Wed May 18, 2011 3:26 pm
Just tried to find a better picture and yes looks like the other side of water bypass hose possibly-------------- though i am pretty certain thatthe one that is on there is longer in dimensions
PIC
perhaps my memory is incorrect just seems a lot smaller in length that i can recall. ( wouldnt be the first time ive made that mistake lol )
So perhaps the two sides are the same
Chris
PostPosted: Wed May 18, 2011 3:45 pm
Yey,,,, after finding that picture i have managed to find out the actual part number and have just ordered it
the number and title is "water bypass hose no 4 16281 - 88380
the one i got i am presuming IS different as number is 16280 - 88380
Thanks for the searches
now let me just hope gets here when they said it would lol
Chris
PostPosted: Wed May 18, 2011 5:35 pm
Car Model: ST165
Dicemans picture and part number is of an equivalent ST185 engine / SW20 Rev1&2 MR2 to be exact
Image vs, Image
# The ST185 has different part numbers for by-pass hoses #4 & #5 , but i seem to remember that they are essential exactly the same hose, diameter and shape iirc.
# The Russian EPC link above ( and my own EPC version on my PC) confirms that the ST165 hose that you need which is found on the rear of the block, uses the same ST185 hose & part number as found on the front of the ST185 block!
# I bet when you get the other hose form Toyota it will be exactly the same. If it is, then i will buy the spare one for my collection.
ST165 turbo 4WD
PostPosted: Fri May 20, 2011 8:12 pm
Hiya Gary.... managed to get the pipe today and its exactly the same in length but the bore size is larger on the one on the rear so they are actually different
Thought id post it up so your records and inventory are correct :)
Chris
PostPosted: Sat May 21, 2011 11:12 am
Car Model: ST165
cheers jingo.
can you please confirm after you have tried for size, which is the correct by-pass hose part number for the ST165 rear block
ST165 turbo 4WD
PostPosted: Sat May 21, 2011 10:30 pm
Fitted and confirmed Gary
PostPosted: Sun May 22, 2011 11:17 am
Car Model: ST165
So the ST165 EPC is wrong ?
ST165 turbo 4WD
