It is currently Tue Oct 07, 2025 12:38 am
PostPosted: Wed Jul 13, 2011 1:39 pm
Hi folks,
like the topic, i started to search for a good clutch that will fit my application and i though you guys can help me 8)
- ~500NM
- max. 8250rpm
- a organic material like carbon is favored
i'am glad for advises :)
PostPosted: Wed Jul 13, 2011 3:06 pm
we used a spec stage 3+ with stage 5 disc in my brothers car.
10k miles, over 400bhp, no problems so far
PostPosted: Fri Jul 15, 2011 8:55 pm
Hi
i think 400hp would be not enought or to near on the boarder, is should be a little bit oversized but not to much
i'am now i contact with carbonetic, exedy is to expensive, is there anyone with a feedback for me?
PostPosted: Fri Jul 15, 2011 9:25 pm
400? the plate is rated to 550lb/ft torque rating. ;)
PostPosted: Sat Jul 16, 2011 12:26 pm
do you have a homepage from them for me?
PostPosted: Sun Jul 17, 2011 12:21 am
the rating of the stage 5 is 570lb/ft.
we used however the stage 3+ cover etc with a stage 5 disc.
better than stock feel on the pedal but massive ability.
http://www.specclutch.com/cars/Toyota/MR-2/1994/Single
the turbo is at the bottom.
but each to their own on clutches i afraid, we have good feedback and others dont like them, so i would look for what you think best.
the specs need bedding in properly for a good 500-1000miles before any hard use which is a pain but then other than that its had some serious abuse and no complaints after 10k
PostPosted: Sun Jul 17, 2011 6:01 pm
i'am possible interested in the super or mini twin type, i contacted them
thanks
PostPosted: Wed Aug 03, 2011 6:23 pm
Clutchmasters FX-600?
Twin organic kevlar discs:
PostPosted: Wed Aug 03, 2011 6:39 pm
to late :(
meanwhile i bought a ATS single carbon clutch :)
i found nearly all twin clutches handle so much NM -> 600PS and more
my thinking was relatively simple, better a broken clutch as a broken gearbox (in hope that the gearbox can handle this :lol: ) , after some mails i decided to go with the Spec2 design and a 1900kg plate which give me a absolute maximum of 600PS in form of a single clutch with less parts, wheight and complexity, the only one point she is rated with up to 20% more pedal force, we will see.....
Users browsing this forum: No registered users and 9 guests
