It is currently Mon Oct 06, 2025 9:41 pm
PostPosted: Tue Jan 27, 2015 12:05 am
Hello Guys
Do you know what this is for ?
It is in the right corner just behind the front light ?
It has 2 wires in it
Regards
Toyota Celica Gt4 1990
Toyota Celica Gt4 1990 Rallycross
Toyota Starlet 1980
PostPosted: Tue Jan 27, 2015 12:28 am
Looks like a regulator or rectifier but would need to confirm.
Does it have a part number stamped on it?
PostPosted: Tue Jan 27, 2015 12:44 am
Injector resistor pack. Required for low impedence injectors with factory ECU. Can be disabled or removed if using aftermarket ECU and high impedence injectors as aftermarket ECU will allow you to control injector impedence
GT Four Adovansu
PostPosted: Tue Jan 27, 2015 10:27 am
If it is a resistorpack would not there be two? The oem place of the resistorpack are abouve the gearbox. A long time ago for me.
ST185 CS #1845
PostPosted: Tue Jan 27, 2015 10:48 pm
It's the fuel pump resistor for low speed.
The injector basllast has 5 wires.
PostPosted: Wed Jan 28, 2015 2:27 pm
I'm with nibbles. Bolted to the underside of the battery tray on a 205, not sure about others
